how adjust idol?
Old Aug 22, 2007 | 07:28 AM
thn116's Avatar
Default how adjust idol?
does anyone know how to adjust the idol for a 1999 honda accord v6?
Old Aug 22, 2007 | 09:02 AM
Hammer99ex's Avatar
Default Re: how adjust idol? (thn116)
you dont, its programed into the ecu
Old Aug 22, 2007 | 01:41 PM
thn116's Avatar
Default Re: how adjust idol? (Hammer99ex)
i can't just do a adjustment to the cable line?
Old Aug 22, 2007 | 01:44 PM
The-Kid's Avatar
Is there something wrong with your <U>IDLE</U> ?
Old Aug 22, 2007 | 01:45 PM
Hammer99ex's Avatar
all that will do is open the throttle plate more than its supposed to be open.... to alter "idle" speed, you need to manipulate the iacv or idle air control valve.
however, bear in mind that it is a pwm (pulse width modulated) componant that is controlled directly by the ecu.
Old Aug 22, 2007 | 02:30 PM
thn116's Avatar
ok, well the idol just runs a bit lower at random times. what do you think? just open the plate?
Old Aug 22, 2007 | 02:58 PM
Hammer99ex's Avatar
no, dont just open the plate... your IDLE! is low for a reason, find and fix the problem thats causing your low idle and you wont have to adjust anything.
Old Aug 22, 2007 | 03:12 PM
el dominicano 24's Avatar
its controoled threw the ecu and your gonna need a scan tool to change it and it will suck up gas if your trying to raise your idle
Old Aug 23, 2007 | 07:35 AM
thn116's Avatar
Default Re: how adjust idol? (el dominicano 24)
i just need slighty raise it, nothing major
Old Aug 23, 2007 | 12:05 PM
JimBlake's Avatar
If you use the little idle bypass (needle valve) in the throttle body, then the ECU will command the IACV to close up a bit to compensate. When it's too far closed the control will become unstable. If you use the throttle cable it'll just be worse. You'll create a situation where the different parts of the idle control system are fighting against each other.
Old Aug 23, 2007 | 08:33 PM
thn116's Avatar
Default Re: how adjust idol? (JimBlake)
well the thing is it will only raise by the smallest amount. i'm not rasing the idle by lot. i think it will be fine overall.
Old Aug 24, 2007 | 04:04 AM
-RedneckDave-'s Avatar
Working
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by thn116 &raquo;</TD></TR><TR><TD CLASS="quote">well the thing is it will only raise by the smallest amount. i'm not rasing the idle by lot. i think it will be fine overall.</TD></TR></TABLE>
He is telling you exactly what to do and also telling you what will happen if you just turn a screw to raise the idle.
Old Aug 24, 2007 | 04:28 AM
GhostAccord's Avatar
If it seem as though your idle speed has dropped that is usually an indication that something has changed and needs to be fixed/corrected. When was the last time you cleaned/changed your air filter? Try that first or maybe put some $$$ into a full tune up.
Old Aug 24, 2007 | 04:33 AM
hondaccord's Avatar
Default Re: how adjust idol? (GhostAccord)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GhostAccord &raquo;</TD></TR><TR><TD CLASS="quote">
If it seem as though your idle speed has dropped that is usually an indication that something has changed and needs to be fixed/corrected. When was the last time you cleaned/changed your air filter? Try that first or maybe put some $$$ into a full tune up.</TD></TR></TABLE> oil change too.
Old Aug 24, 2007 | 05:31 AM
thn116's Avatar
Default Re: how adjust idol? (hondaccord)
i'm due for a tune up soon, so i guess i'll try that 1st before messing with the idol.
Old Aug 24, 2007 | 09:45 AM
YeuEmMaiMai's Avatar
do what was suggested by cleaning intake, and changing plugs oil and filter
Old Aug 24, 2007 | 06:22 PM
H2290's Avatar
Seriously, how many hints were thrown that the correct spelling is IDLE? Too much Americon Idol has him messed up on the difference. Their is a difference or is they're?
On topic: I agree, don't just adjust the screw, find out what has changed to cause the idle to be different.
Old Aug 25, 2007 | 05:11 AM
hondaccord's Avatar
Default Re: (H2290)
you may want to use the seafoam see if it doesn't clean up the motor and all.
Old Aug 25, 2007 | 10:05 PM
thn116's Avatar
Default Re: (H2290)
gezzz let the whole spelling thing go, don't you have anything better to do? i guess not...
Old Aug 25, 2007 | 11:06 PM
dwayne1413's Avatar
Default Re: (thn116)
its "idle" just so you know. everyone has been capitializing on it and after all that you still never noticed. When the car is in park it IDLES, when your sitting at a red light your car IDLES. If your sitting at home on a monday night, your watching America IDOL.
Old Aug 27, 2007 | 03:52 AM
Default Re: (dwayne1413)
Give it up on the spelling crap. This is a tech form for cars not perfect English. The people trying to help this guy out knew what he was asking.
Oh just so you know 1413. The words "it's", "everyone" and "monday" from your post are all supposed to be capitalized.
Old Aug 27, 2007 | 11:54 AM
dwayne1413's Avatar
Default Re: (GhostAccord)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GhostAccord &raquo;</TD></TR><TR><TD CLASS="quote">Give it up on the spelling crap. This is a tech form for cars not perfect English. The people trying to help this guy out knew what he was asking.
Oh just so you know 1413. The words "it's", "everyone" and "monday" from your post are all supposed to be capitalized.</TD></TR></TABLE>
at least they were spelled right and used correctly
Old Sep 2, 2007 | 06:48 PM
thn116's Avatar
hey ghost accord thanks. as for you dwayne1413 i'm guessing you don't know the answer to my question, so you're just spell checking because you have nothing better to do. wow you life must really suck. as for anyone else who wants to try to bust on me for messing the spelling up, this goes to you to. so if you don't know the answer, don't bother posting because you're just taking up space.
white_ej6
Feb 7, 2010 04:43 AM
aznoophi
Mar 28, 2008 01:32 PM
NAmodified
Dec 5, 2007 04:04 PM
cj7420
Mar 24, 2002 06:55 AM
