Help
Old Mar 18, 2021 | 11:16 PM
Shaggymo's Avatar
Default Help
I have a 2000 Honda Accord 5 spd. I can’t rev over 4K. Idk what it could be but when it hits 4K it kinda sputters?
Old Mar 19, 2021 | 04:46 AM
hondaslave1342's Avatar
Default Re: Help
Engine light on? Is this occur while driving or in neutral?
Old Mar 19, 2021 | 06:34 AM
JuanMoellenkamp's Avatar
Default Re: Help
I think you talk about rpm?
In case of the Rpm you might want to think of changing to a new larger rims perhaps 19" then it can save a little bit more miles every circle circulation
as it best use of power and rpm from the engine
Old Mar 19, 2021 | 08:40 AM
99stockcivic's Avatar
Default Re: Help
@JuanMoellenkamp You should not be offering advice, it seems you don't really have a grasp on physics or engine design and power bands. For the original poster, please ignore this person.
@Shaggymo What have you done ti diagnose thus far? 4k sounds like one of those numbers where you might have a VTECH issue, often a bad vtec solenoid can cause this. You could also have the car in a limp home mode. Have you scanned the car and read any errors that might be in the ECU? That would be very helpful.
If you want to take a look at the vtec solenoid, it's often the gasket that has failed, so check that first, but the solenoid can also go bad, but you might get lucky and replace a gasket, clean it out and it could be what the trouble is.
take a look here on how to do it.
richiedan40
Oct 24, 2017 04:16 AM
jdmwojo
May 3, 2011 09:57 AM
ONE-CAM-EF
Jun 20, 2008 11:50 AM
bmacc
Honda Civic (2001 - 2005)
12
Jul 26, 2007 05:10 PM
purpl7duece
Aug 25, 2002 11:32 PM
