Header help.
Old Aug 2, 2011 | 10:42 AM
rayo53's Avatar
Default Header help.
Tried searching to no avail.
I have a 97 Accord LX 5 speed. The headers have a small gap between them.
I know it'd be way easier to get pictures, but I'll have to do it later. Basically, in between the 1st and 2nd "tube" and in between the 3rd and 4th, there's a gap where the header has rusted down.
Pictures later, any help?
Old Aug 2, 2011 | 01:47 PM
MAD_MIKE's Avatar
MM Gruppe B
Default Re: Header help.
Rusted down? As in crack/corroded and there's a hole?
No real cheap way of fixing, just replace it if it has failed.
Old Aug 2, 2011 | 03:10 PM
GhostAccord's Avatar
Could see about getting it welded if it is mild or stainless steel.However if it is the stock cast manifold you would probably be better off finding a new one.
Old Aug 2, 2011 | 10:45 PM
rayo53's Avatar
Where it looks corroded down.
Old Aug 3, 2011 | 02:29 AM
MAD_MIKE's Avatar
MM Gruppe B
1. Not everyone have facebuck
2. I see a very red cam cover, and a couple of busted studs(fix those).
3. I don't see a 'rusted down' section.
Old Aug 3, 2011 | 08:48 AM
rayo53's Avatar
How do I fix the studs, because I'm thinking it could be the gasket.
Old Aug 3, 2011 | 12:23 PM
Fix the studs???? What's wrong with them? A really easy fix would be to replace them. However, I have no idea what is wrong with them. Therefore I cannot say for sure what might help!
Post up some pictures or at least some sort of description of your issue. That would probably lead to more precise help! If you have posted up pictures or a link I can't see them.
Old Aug 3, 2011 | 05:08 PM
rayo53's Avatar
When I can get a hold of a camera, I will. Thanks in advance everybody.
Old Aug 3, 2011 | 05:43 PM
If they are snapped off you will probably need to unbolt the header. Pull it out of the way. Then you might be able to get at a part of the stud in order to remove it. Clamp onto them with a pair of vise grips. They screw out counter clockwise like any other bolt. Spray them down with some WD-40, PB blaster, or some other penetrating oil. If you have access to a small propane/butane torch that could be useful as well.
mikeycivic
Welding / Fabrication
15
Feb 10, 2010 06:39 PM
boobafett
Jul 14, 2009 06:04 PM
project4dr-eg
Apr 22, 2008 04:13 PM
fauxhawkid
Jan 12, 2006 04:04 PM
