g23 help
Old May 21, 2009 | 06:29 AM
KraKimus's Avatar
Default g23 help
i'm about to start my g23vtec project but no one will answer my question....whato do i need besides my f23 block and a h22 head? i'm already gonna put k20 pistons in it. i need to know like will my same wiring harness work? and do i have to block off the two remaining drain holes? please someone answer me this time.
Old May 21, 2009 | 07:29 AM
hondafreak2134's Avatar
Default Re: g23 help
you do have to block off 2 remaining drain port on the h22 head. not to sure about the harness but i beleive its suppose to work i am currently working on this project to. you will need a h22 crank cog, h22 timing belt, and you will need to take the gead off the h22 water pump and press it into the f23 water pump. those are the important things you will have to do. as for the distributor not to sure, and you will need a p13 ecu, p28, or p78 but the p28, and p72 have to b chipped to be used with the build. lastly a conversion harness for your ecu. is your car auto or manual?
Old May 21, 2009 | 09:37 AM
KraKimus's Avatar
what exactly does cog mean? like what is a cog?
Old May 21, 2009 | 10:11 AM
haha i had the same question at one point the cog refers to the gear that sits behind the pulley http://www.hondaautomotiveparts.com/...NKSHAFT-PISTON. go to the site and a picture should show up if it doesnt go to the prelude 93 v tec or which ever engine you are using. and the crank cog or crank gear (same thing) should be number 16, it fits behind 18 and 15
Old May 21, 2009 | 10:22 AM
GhostAccord's Avatar
Hondafreak2134, Get yourself ready for a long term spoon feeding now!
Old May 21, 2009 | 11:44 AM
and by that you mean?
Old May 21, 2009 | 11:53 AM
It was meant as a kind of jovial warning to you. A warning that you should be ready for a lot of PM's regarding every single nut and bolt required for the OP to complete this build from here on out. aka spoon feeding....
Old May 21, 2009 | 03:38 PM
lmao thanks for the heads up. but im just trying to help cause i know how i felt when i didnt know anything, and no one helped me.
Old May 21, 2009 | 09:16 PM
Well the G23 has been done a few times. I have seen threads where people get no answers and that it's tough to get help. I have no idea what it takes.
I think PirateMcFred has been working with H23 & F23 DOHC VTEC builds for a while now. Maybe you should check out some of his stuff. Try using the advanced search. Use the keyword "G23" and in the search by user name field put "PirateMcFred". See what that gets ya.
Old May 21, 2009 | 09:28 PM
hon2984's Avatar
I'm pretty sure you existing harness will work, i'm sure you will have to add in wires for the VTEC solenoid & pressure switch. I know that the H23 head bolts are the same the same as the F23,F22A,F22B, There is a good chance that the H22 uses the same head bolts.
You will need a tuneable ECU. Phearable.net is pretty cheap and have quality products.
Old May 22, 2009 | 08:15 AM
Sam1am26's Avatar
F23 Parts
- Block
- Head gasket
- Water pump (The housing)
- Rear Water Pipe (to connect with H22 water pipe)
H22 Parts
- Head (Complete...Valvetrain, Cover, Dist, Manifolds, VTEC Solenoid, Etc.)
- Water pump (Just the gear)
- Rear Water Pipe (to connect with F23 water pipe)
- Timing Belt
- Crank Gear
- Crank Pulley (Only if you are using H-series alternator. I recommend using the F23 alternator bracket though cause the F23 dip stick bolts to it.)
Modifications
- You have to plug two oil drains in the h22 head that do not exist on the f23 block...
- You have to use the h22 upper water pipe and connect it to the lower part of the f23 water pipe... You will have to either weld it together or connect it with rubber hose...
- You also have pull the gear off of an f23 water pump and install an h22 gear on it because the H-Series water pump is different...
I'm probably forgetting something. It's been a while. If I remember anything else I'll update this post...
Here is my old F23/H22 thread if you want some more info. It was boosted but building the motor is the same. Sorry my pics don't work anymore.
//www.honda-tech.com/showthread.php?t=1069869
And here is the thread that started it all by prelittlelude. It is long but it has all the info you could possibly need in there...
https://honda-tech.com/forums/honda-prelude-4/f22b2-block-h22a1-head-f22-vtec-f22b-vtec-776837/
And this is PirateMcFred's F23/H23 thread. It's with an H23 head but tons of good info in there as well...
https://honda-tech.com/forums/honda-prelude-4/new-frankenstein-engine-%3D-g23-f23-h23-write-up-long-56k-beware-1046336/
Old Sep 6, 2022 | 10:13 AM
King Jafi's Avatar
I’m new to the forum but I’m completing my g23 swap and after replacing everything & I MEAN EVERYTHING, it’s not revving properly. I was thinking of changing wiring harness from the original’93 Accord lx, to the’97 prelude harness. I’m getting everything except a proper revv, I’ve gotta press the pedal several times to get a decent response from the car. I haven’t connected the vtec yet, but everything is connected and it’s a couple that don’t connect to anything🤷🏽. A little help??
Old Sep 6, 2022 | 10:45 AM
Aradin's Avatar
Premium Member
Is it tuned?
Old Sep 6, 2022 | 11:06 AM
King Jafi's Avatar
Originally Posted by Aradin
Is it tuned?
nah, not tuned. Only the h22a 4 intake, head,& manifold. It’s on a f23 a4 block. I’ve got 3” exhaust but nothing else on it
Old Sep 6, 2022 | 11:45 AM
Aradin's Avatar
Premium Member
You need a chipped ecu and a professional tune.
KurtPierce024
Jan 12, 2013 02:08 PM
JDMlude3189
Aug 11, 2009 06:49 PM
Nexus1155
Jan 27, 2008 06:26 PM
monster accord
Jul 1, 2007 06:36 PM
big lou
Dec 28, 2003 05:03 PM
