F22b 1995 Honda Accord AXLE ISSUE!!!!!
Old 11-09-2009, 08:23 PM
New User
Andrew1k's Avatar
Default F22b 1995 Honda Accord AXLE ISSUE!!!!!
Well i just picked up my 1995 honda accord wit ha f22b non vtech 5speed manual not sure what the tranny is
but i just got it 5 days ago and the front passenger side axle totally took a sh*t and snapped off......
....sooooo today i went to a axle shop and got the front axles replaced.....brand new axles same size as the ones that were on it already....
..well........the guy took it out for a spin but before he could even leave the parking lot......the passenger side axle snapped again.........soooooo me and about 4 mechanics and my dad put in the air and checked out AGAIN and we figured it was because the axle wasnt long enough....so we got the same size one as the driver side axle.......the same part and evertthing witch was about half an inch longer and put it on....
was driving great ran so smoothe i was loving life again in my clean accord and then.......my life took a turn for the worse........and as i was coming home from replacing some bulbs on the car....
the passenger side axle...........came loose atleast it looks that way to me cause there was nothing missing off it like the other ones i mean the other ones when they broke the metal was torn like paper and everything but this bigger axle looked like it was still being installed it was just hanging there with the boot and everything so.....idk wat it could be.......anyone that can throw me some suggestions PLEASE PLEASE PELASE DO i would greatly appreciate it and i will be posting pictures in a little bit.
1995 Accord Ex Coupe F22b non-v 5 speed
Multiple Axles and still not working HELP!!!
Old 11-09-2009, 09:44 PM
bseriescrxsi's Avatar
Default Re: F22b 1995 Honda Accord AXLE ISSUE!!!!!
the axles on the driver and pass side are different if you look at the splines they are different on a 5 speed...if you put the driver one on the pass side it WILL NOT lock into the transmission whic h is the problem i believe you are experiencing it will slide and eventually fall out do to turning......as for your broken axle issues i cant really help u there as ive done f22b swaps on 90-93 accord with their axles with no issues.....
AUTOZONE PART INFO:
(95 accord f22b(with v-tec)
Duralast Reman / CV Halfshaft
Part Number:
8035
it is the same part number for the non vtec also.....now 90-93 use part number 7073....goodluck but your problem t5his time was the spline will not luck in using the driver side on the passenger side(all part number mentioned are for driver side axles)
Old 11-10-2009, 12:23 AM
cctgene's Avatar
I'm not sure I understand what you mean when you say, "axle snapped off". Did the axle shaft break or did the c/v joints come apart?
Old 11-10-2009, 08:38 AM
New User
Andrew1k's Avatar
I need the part number for the Passenger side Front Axle. Thats the one that slipped out. Right now we have TWO Driver Side Front Axles on both the driver side and Passenger side. And as I found out that didnt work to well
And When i mean snapped off the CV joint ripped apart cause the axle was to short that is why we switched to the longer one but as we found out it didnt work as well.
So i have no idea what to do for a part cause im not sure there is a longer passenger side axle for a 1995 accord.
Old 11-10-2009, 09:27 AM
cctgene's Avatar
For what it's worth, the NAPA on line site list the following axles for your car:
Right - new part# 946017 CV shaft length 24 9/16"
Left - new part# 946015 CV shaft length 24 3/8"
Old 11-10-2009, 11:10 AM
New User
Andrew1k's Avatar
Alright everyone just got back from the shop and this what were gonna try on day 2 of my 1995 Accord axle crisis!
1997 Honda Prelude passenger side axle! Will it fit on my f22b2 1995 Honda Accord?
only time will tell if not i think im gonna have to go with a custom fitted one and drop the $130 for it and the time
Old 11-20-2010, 02:51 PM
big_b45044's Avatar
i am having problems with my 91 accord axle on the passenger side. every time i turn the wheel, dont matter which way the axle shaft pops out of the cv joint.new mounts ball joints tie rod.i need to get it figured out so i can take the kids back and fourth to school.any help would be great.
Old 12-12-2010, 07:08 PM
big_b45044's Avatar
what would make my passenger wheel tilt inward all kinds of new parts ball joints bushings please i need this fixed
Old 12-12-2010, 07:13 PM
19Accord97's Avatar
Replace the axle with the recommended part. I don't know why you would try some random combo, have it break again, then want to try another combo.
Axles from Autzone, Advance, etc. are known to not be of the best quality. May have just gotten some bad ones. Hell, when I had my drivers side replaced, they had to get one from Autozone, Carquest, and Advance because all of them were to long. idk wtf was up with that.
Old 12-12-2010, 07:30 PM
big_b45044's Avatar
my axles are oem from dealer i had the car slammed and raised it back to stock.i've put new inner and outer control arm bushings sway bar bushings and endlinks.new lower ball joints and upper control arms.it just on the passenger side. all my parts where from the dealer aka stealer
Nebrethar
Classic Hondas
09-03-2017 02:17 PM
jonesEK
04-13-2017 12:45 AM
BeastlyB
05-19-2014 01:55 PM
andrew55ap
Honda CR-V & Element
10-20-2011 11:41 AM
rexload
08-11-2008 05:18 PM
Quick Reply: F22b 1995 Honda Accord AXLE ISSUE!!!!!
