F20B & H22A
Old 03-29-2003, 10:04 PM
cpforyou's Avatar
Default F20B & H22A
Does anyone know if the F20B Accord SiR-T block will mate with an H22A head?
Old 03-29-2003, 10:14 PM
KTeller8's Avatar
Default Re: F20B & H22A (cpforyou)
should, i ve seen a few. that come through our warehouse. not bad pickup for like 1100 shipped
not sure why youd want to throw the h22 head on there. dont know if it will help to much both are dohc and vtec
Edit: sorry i was talking bout the f22b dohc lol
[Modified by KTeller8, 1:15 AM 3/30/2003]
Old 03-30-2003, 07:20 AM
New User
Nick H's Avatar
Default Re: F20B & H22A (KTeller8)
it probably won't due to the fact that the bores are different on the two motors...
SiR-t has an 85mm bore
H22 has an 87mm bore
Old 03-30-2003, 07:37 AM
cpforyou's Avatar
Reason I ask is because I'm did an F20B swap for my friend. However, another guy is selling a built H22A head, complete with valvetrain, skunk2 cams, etc. That's the reason why I ask.
[Modified by cpforyou, 4:38 PM 3/30/2003]
Old 03-31-2003, 10:11 AM
ALLMOTOR18's Avatar
How much do you do swaps F20B swaps for?
Old 04-04-2003, 11:04 AM
cpforyou's Avatar
Default Re: F20B & H22A (gsrtyper)
PM me for a quote.
Old 04-04-2003, 11:05 AM
ALLMOTOR18's Avatar
PM me for a quote.
what shop is it?
Old 04-04-2003, 10:42 PM
cpforyou's Avatar
You have PM!
Old 04-08-2003, 08:13 AM
Showoff's Avatar
Yea what are the reading for F20B JDM motor meaning HP and TQ stats and redline ? i have an JDM H22A and got lucky getting one with an type S tranny and LSD i was thinking building the F20B motor will H22A parts fit ? or should i build the H over the F motor ? and does the F20 likes to rev better then the H22a ?
Old 04-08-2003, 12:33 PM
cpforyou's Avatar
Default Re: F20B & H22A (Showoff)
F20B Specs:
2.0L (1997cc) DOHC VTEC Engine
200HP @ 7200RPM
20.0 KGM @ 6600RPM
11.0:1 Compression Ratio
Bore X Stroke: 85.0 x 88.0
H22A Specs:
200HP @ 6800 RPM
22.3 KGM @ 5500 RPM
10.6:1 Compression Ratio
Bore x Stroke: 87.0 x 90.7
H22A Type S Specs:
220HP @ 7200 RPM
22.5 KGM @ 6500 RPM
There are pros and cons with F20B over an H22A.
F20B as you can see, has a smaller bore, and a shorter stroke. This results in less torque. The walls are thicker due to a smaller bore, and it can rev higher than an H22A. This allows more horsepower at high end, as well as taking advantage of gearing in such high RPMs.
H22A has a bigger bore and stroke, and a worser R/S Ratio than an F20B. Because of this, the walls are thinner, and it cannot rev as high as the F20B w/o being BUILT. You do however, have more torque off the line, but your high ends tapers off sooner than an F20B.
For a Civic, it might be better to go with an F20B, since the torque in the F20B is already more than enough. For an Accord or Prelude, the H22A might be better since those cars are heavier to begin with. Each has its pros and cons.
Old 04-11-2003, 03:05 PM
All-Motor H22A's Avatar
If you ask me, I don't think the F20B is worth it. With more torque, you can start of the line quicker, get lower 60 foot times, and pull harder throughout the run. The stock block can handle 8000RPM on stock bottom end. No need to go up to 9000RPM when you have so much torque.
uneed8
02-25-2009 05:17 PM
TegProject
03-05-2007 12:14 AM
sitinthehall
07-30-2005 01:44 PM
H22HondaCRX
02-19-2005 02:57 PM
0ptimus prime
04-25-2003 07:19 AM
Quick Reply: F20B & H22A
