Error Code
Old Aug 16, 2007 | 09:49 AM
kaitech's Avatar
Default Error Code
I get an error 41 from the engine light after jumping the service connector, Should I replace the O2 Sensor this is a 92 accord LX
Old Aug 16, 2007 | 09:56 AM
Duane_in_Japan's Avatar
Default Re: Error Code (kaitech)
I believe that a 41 is for the heater portion of the O2 Sensor, it can be tested and verified if the heater is out of resistance (ohm) spec, broken wire going to the O2S or a blown fuse that would power the heater. Oh, dont forget the corroded connector or chaffed (grounded) wire.
Old Aug 16, 2007 | 09:57 AM
kaitech's Avatar
Default Re: Error Code (Duane_in_Japan)
where is that located? I noticed some wire(cooper not shielded going into the sensor?
Old Aug 16, 2007 | 10:06 AM
How many wires going into the sensor, I bet the car runs just fine, YES. You are going to need a Haynes repair manual or someone else here to teach you how to test the sensor.
All wires should have rubber coating around them (insulation).
Old Oct 23, 2008 | 11:19 PM
gamakichi77's Avatar
i did found and seeing this O2, which are come with 4 wires and 3 wires..which one is for OBD1?
gitarman2
May 10, 2013 06:52 PM
ShortyzKustomz
Nov 1, 2007 06:24 PM
JasinC19
Oct 11, 2007 09:47 AM
98exturd
Aug 12, 2007 02:31 PM
team 15
Feb 20, 2007 08:29 PM
