O2 sensor
Re: O2 sensor
It would probably help to mention the reason I was even looking is because I got 2 o2 related codes. First is A/F sensor 1 heater system malfunction (P01135). Second is Secondary Ho2S12 circuit heater malfunction (P0141). I assume the first code has something to do with how the previous owner wired this. The second code is just because there is no second sensor plugged in.
Re: O2 sensor
Well you found your problem.
The o2 sensor is 4wire setup. 2 grounds and sensor out and heater 12volts.
Connect that wire and maybe it will clear out the first light.
If it was me i would get the right connecter and wire it in better.
JoshJosephKeith
05-04-2009 04:38 PM
CereaLand
06-30-2004 12:01 PM
