Engine Identification
Old Jun 13, 2025 | 10:36 AM
MZLK's Avatar
Icon4 Engine Identification
I have recently bought a Honda that stated it was engine swapped, but never really told with what engine. Now that the corner piece of my #4 runner on my intake manifold is broken off, im looking for a replacement. For some reason, I cannot find it anywhere, I have seen P5L-1 on the heads, so I am assuming there are the 97-01 JDM Honda Prelude heads. I also found just the serial number where the model number is usually. The code is 1106258. If anyone has any clues as to where I should be looking for an intake manifold I would greatly appreciate it.
Old Jun 17, 2025 | 09:25 PM
MAD_MIKE's Avatar
MM Gruppe B
Default Re: Engine Identification
With the hood open, look at the front engine mount, above the black bracket should be a raised square pad on the block that will be stamped 'H22A', if the pad is filthy you may need to clean it to verify what the block actually is.
If it was head swapped it could be an 'F22' with an H head. Or if non VTEC it could be an DOHC F20, F22B, or H23.
AFAIK H22 VTEC heads are all pretty much the same.
coot_er
Honda Civic (2006 - 2015)
Aug 23, 2010 05:02 PM
elpiar
Nov 26, 2006 05:05 PM
kotetu
Acura NSX
Dec 20, 2004 03:39 PM
mike90exr
Nov 8, 2002 11:35 PM
RAB
Sep 25, 2002 04:06 PM
