eheck engine light
Old Sep 19, 2008 | 10:22 AM
92hondaaccord8108's Avatar
Default eheck engine light
My check engine light is on. How do i check it to find out whats the problem?
Old Sep 19, 2008 | 12:41 PM
slomofo's Avatar
GDD Member
There's a plug near your glove box, actually there's two plugs, one is a three pin and the other is a two pin. You can either plug a scan tool into the three pin and pull codes or shover a paperclip in the two pin and pull codes by counting the number of times your check engine light flashes.
Old Sep 19, 2008 | 01:29 PM
Default Re: (slomofo)
where are these 2 plugs at?
Old Sep 19, 2008 | 01:36 PM
slomofo's Avatar
GDD Member
If it's never been done before, it'll be taped up and you might have to pull your glove box down. It's to the right of the glove box and there's a rubber thing they slide into. One of the plugs is gray, the other is green.
Old Sep 19, 2008 | 01:47 PM
well i pulled down the glovebox and look to the right and saw nothing but i found this rubber thing that has wires in it and it runs down to the door and i found a bunch of plugs down there and i found a grey 3 plug and a brown 2 plug. what color are the wires coming out of them?
Old Sep 19, 2008 | 01:54 PM
Default Re: (92hondaaccord8108)
also i found a blue 2 plug tape around this long rubber thing with wires in it
Old Sep 19, 2008 | 02:10 PM
slomofo's Avatar
GDD Member
That's it.
Old Sep 19, 2008 | 02:12 PM
what's it the blue the brown one or the grey one? which one is it?
Old Sep 20, 2008 | 09:43 AM
so which one is it?
VtecCivic93
Sep 2, 2009 10:06 PM
righteyeblind
Jun 30, 2008 01:50 PM
TyfinHX
Apr 28, 2007 01:57 PM
Draven_Von
Honda S2000
Jul 19, 2004 06:43 PM
Bampf
Mar 18, 2002 06:45 AM
