Drive 4 Light Flashing and Speedometer and odometer not working 1995 ACCORD
Old 09-11-2003, 06:19 PM
ac23's Avatar
Default Drive 4 Light Flashing and Speedometer and odometer not working 1995 ACCORD
It was random, but while driving the indicator for what gear I am in, began flashing and my odometer and speedometer stopped working. Is there any easy inexpensive fix for this ? A mechanic quoted me $300, is that a realistic estimate ? Can I get a replacement from a junk yard cheaply and possibly do it myself as an unexperienced person. If you have this part or any suggestions please e-mail me at anolimit98@aol.com
Old 09-11-2003, 07:00 PM
blueHwrench's Avatar
Default Re: Drive 4 Light Flashing and Speedometer and odometer not working 1995 ACCORD (ac23)
The speed sensor is failing. You need the electrical portion only, not the part with the p/s valve in it. It's about 75 bucks new, and fairly easy to install. A used one might be cheaper, but could also be bad, being that this is a common problem in Accords. It's located on the backside of the tranny, above the area where the axles go into the differential. It has a 3 wire connector, and one long, shouldered bolt to hold it in (10mm head). Gravy job, you can do it yourself. If you can't figure it out, let us know
vanyawatson
09-28-2022 09:30 PM
mistablake
01-22-2006 01:03 PM
shaveman
08-07-2005 03:37 AM
Hurricane
09-20-2004 08:13 AM
DIYaccord
10-07-2003 11:41 PM
Quick Reply: Drive 4 Light Flashing and Speedometer and odometer not working 1995 ACCORD
