coolant level in reserviour??
Old 12-09-2008, 07:41 AM
sleepyone's Avatar
Icon2 coolant level in reserviour??
just a quick one..
how much coolant should there be in my reservior on my 2002 v6 accord when my engine is
a) hot
and
b)cold
as i am totally clueless about the concept of a rad/reserviour?
if the level is at the bottom cold and at the min level when engine hot, do i need to add coolant?
how much coolant should i be adding?
please advise?
thank you
Old 12-09-2008, 07:43 AM
Genuine Rolla's Avatar
Since your cooling system is pressurized, when the car cools down and heats up, the radiator will suck in or put back in..whatever it needs from the reservoir/over flow tank. When the car is cool, take off the radiator cap and see where the level is in the radiator.
Old 12-09-2008, 09:58 AM
P_Adams's Avatar
Under ideal conditions, it will find it's own level. There should be two level marks molded into the bottle body; one marked "cold", the other marked "hot". If it's somewhere between the two, you're golden
P
Old 12-09-2008, 10:09 AM
sleepyone's Avatar
P
im well below that tho.. would you suggest me filing it wiht your generic coolant?.. the rad is full when i just checked it a couple mins ago
Old 12-09-2008, 10:11 AM
Jas9848's Avatar
wouldn't hurt to add a little. there is a hot and cold line on the bottle. when the engine is cold the coolant level should be at or a little above the lower line, so yes add some.
Old 12-09-2008, 11:35 AM
sleepyone's Avatar
thanks for your help, much appreciated..
Old 12-09-2008, 04:34 PM
P_Adams's Avatar
GTH (Glad To Help)
P
ShadowDaisy82
11
08-07-2015 10:34 PM
corince06
06-11-2008 12:48 PM
dhn
23
01-05-2008 01:06 AM
JDM00SI
01-26-2005 01:21 PM
drumsy
09-12-2002 07:14 AM
Quick Reply: coolant level in reserviour??
