for 4doorh22
for 4doorh22
Hey man, i heard about you tire setup and i would like to know how it works for you?
please give me your up's and down's of this
Re: for 4doorh22 (KTeller8)
Why don't you PM him?
i agree
i agree
Re: for 4doorh22 (GZERO)
The H-T PM feature does not have to be "live". You can PM him now and the next time he is on H-T he will recieve the message and be able to respond at his convience. Its perfect for when you "dont feel like chatting".
i agree
ok, i just didn't feel like chating today, that's it, please don't post this again
i agree
Re: for 4doorh22 (Kazmans94cord)
Oh, yes, well the Potenza S03 is an excellent tire. Great grip of course and decent ride and noise for a performance tire. I don't know of anyone who would hesitate to recommend this tire. What it really comes down to is what else are you considering. Like the Azenis or Comp T/A K/Ds will have more absolute grip but not last as long.
Re: for 4doorh22 (Wont be beat)
Oh, well, that worked, but was a band-aid solution for a temporary problem (225/50-15s on 15x6.5" wheels). I'd much rather have a proper wheel offset than a spacer. The long studs are nice and strong and chicks love them but are not necessary with a proper wheel.
Not to answer for Dave, but the wheels you now have had the 225s on them. There was rubbing somewhere on the inside, so he had to use spacers, which necessitated the use of longer wheel studs, as the lugnuts didn't have enough threads to hold on to. With the Koseis (which are 7" wide), they aren't necessary...but like the man said, the chicks certainly do dig it. *guffaw*
The spacers were required to avoid the 225 tires rubbing on the top of the rear kunckle with the 15x6.5 (dunno offset) Prelude wheels. When I put the 225 tires on a 15x7 .38 ET Kosei K1 there was plent of clearance. No rubbing and no spacer required... BUT the tires stick out about 1/4" past the fenders and rub under full compression. A 15x7 .45 ET whell may clear the fender with a 225 tire, but might rub the knuckle. Oh and this all depends on the year/model car. So ummm this entire thread and answer is useless 'cause the a car has not be specified.
So the spacers arent necessary with 225 tires?
Re: for 4doorh22 (4doorH22)
thanks for your info
Oh, well, I'm not sure if the 4th and 5th gen suspensions are identical or not.
You're going to have to find a 5th gen owner who has the exact tire/wheel combo you want and see if it works. I wonder who referred you to me...
Re: for 4doorh22 (SOHCArchangel)
NO MAN, its all depends not so much the width but a combo of the width of wheel and the offset, i am running 225's w/o the need for spacers now
4doorh22: "Wont be beat" refer me to you cuz he knew that you where doing something like that, thanks for the info you gave me it was usefull. as for the tires you say the potenza S03? i like the potenza line of tires i think they are pretty good for performance and ride.
[Modified by GZERO, 8:33 AM 10/2/2002]
oh that ignore comment was for dave mostly
but i have a 5th gen 2dr ex im running 225/45/16 16x7" wheels with a +45 offset, no rubbing (mind you i have no plastic fender liners up front) i will be going to a 16x7.5" or 8" width with a +42 offset eventually (if i can find such a inexpensive beast)
