Code 36 CEL, need help!
Old May 18, 2007 | 12:55 PM
jniner's Avatar
Default Code 36 CEL, need help!
I have an H22a swapped into an Accord i have an auto p13 ecu. It throws code 36 which is traction control, i think it had something to do with auto preludes. My question is how do I fix this, will i need to bypass some wires to the ecu, or do I need the 5 speed p13?
Old Jan 20, 2015 | 09:39 PM
Asghar Ali's Avatar
Default Re: Code 36 CEL, need help!
Old Jan 20, 2015 | 11:13 PM
MAD_MIKE's Avatar
MM Gruppe B
If you have a 5 spd, then yes use a MT ECU.
If you have an AT, you will need to use the AT ECU to properly work with the AT TCU.
If the ECU you are using is a JDM spec variant, find the US/Calif version. Stored codes will cause a fail at smog even if your CEL does not light.
Brewer
Jul 7, 2004 01:49 PM
crvtt96
Jun 6, 2004 04:00 PM
tiresmoke
Feb 26, 2004 05:57 AM
Lei Siew Long
Apr 24, 2002 09:27 AM
