Cleaning IACV, FITV and TB
#255
#256
Re: Cleaning IACV, FITV and TB
Disconnect the battery negative cable then go in and step on the brake pedal for 10-15 seconds. This will drain the power from the ECU. You can reconnect the battery after 1-2 minutes.
#257
Earlier in this thread someone mentioned to find the radio anti theft code prior to resetting the ecu. What exactly does that have to do with resetting the ecu? Will it make the car not start?
#258
No sir, It has nothing to do with resetting the ECU. It was a word of caution for people with the stock stereo.
Because, if you have an original stereo and you drain the power from it. The stereo will not work without the code being entered back in when you power it back up.
#261
Re: Cleaning IACV, FITV and TB (TouringAccord)
Originally Posted by ;26759871
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TouringAccord »</TD></TR><TR><TD CLASS="quote">
couldn't you just pull the ecu fuse? that way you don't have to worry about the radio.</TD></TR></TABLE>
Yes.
But we've got a bunch of people in this thread, different year cars, etc. The ECU fuse isn't always the same fuse # in the same fuse box, and it doesn't always maintain the stereo security.
For '98-02 Accords, pull fuse #13 in the fusebox in the right end of the dashboard (near the door hinges).
Yes.
#263
Same symptoms 99 accord believe my egr clogged completely nd maybe even my cat from problem not being dealt with I just got the car wish I knew how to upload short video clip of the idle I've been going crazy cap rotor in switch relay... starter fluid to intake wen I noticed the backfire burp and carbon build up in inside of t.b and black carbon on ground behind exhaust any other opinion or input greatly appreciated
#264
Re: Cleaning IACV, FITV and TB (Grandhustleman86)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Grandhustleman86 »</TD></TR><TR><TD CLASS="quote">....any help on resetting it?</TD></TR></TABLE>Disconnect your battery for a couple minutes. But first, find your radio anti-theft code...
Then, start the engine without touching the gas pedal. Let it idle to warm up completely without touching the gas pedal. After the radiator fan comes on, you're done.
B_Swapped93
02-27-2013 09:05 AM
sik_sol
08-18-2006 02:08 PM
