Checking codes- what does a solid CEL mean?
Old May 30, 2008 | 08:14 PM
jmccalip's Avatar
Default Checking codes- what does a solid CEL mean?
Is the ECU bad?
Old May 30, 2008 | 08:23 PM
hondadude's Avatar
Default Re: Checking codes- what does a solid CEL mean? (jmccalip)
could you tell the whole story?
The diagnostic tree for CEL always on is called a "hard code"and then you have to go into symptoms of the problem, as in.....what the engine runs like.
any other info would really be helpful.
Old May 30, 2008 | 08:32 PM
jmccalip's Avatar
Default Re: Checking codes- what does a solid CEL mean? (hondadude)
Thanks for the fast reply.
The engine runs fine, nothing seems wrong at all. The thing is, I just got my timing belt done and now the MPG seems a lot lower(just watching needle and odometer).
Old May 30, 2008 | 10:43 PM
hondadude's Avatar
Well some kid "Grandhustleman86" has informed me that I am not allowed to help people or ever post information on this website.
The only recourse is to wait for a moderators decisions. Or you can report this post to the moderators.
This is a corp. owned website now and I can't afford a lawsuit.
Old May 31, 2008 | 03:12 AM
361 accord's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondadude &raquo;</TD></TR><TR><TD CLASS="quote">Well some kid "Grandhustleman86" has informed me that I am not allowed to help people or ever post information on this website.
</TD></TR></TABLE>WUT DA ***!!!!
Old May 31, 2008 | 05:33 AM
GhostAccord's Avatar
WTF x2 He sent that to you in a PM........
To the OP,
If you are checking codes via the SCS pin connector short method. A solid CEL means that there are no codes stored on the ECU aka no problems found.
A solid CEL when you turn your ignition to the on position, without the SCS shorted, and without starting the car. Means there was a problem found during the ECU test curcuit. aka possible bad ECU
Old May 31, 2008 | 08:57 AM
TheMuffinMan's Avatar
He knows where you live!
Solid CEL in my experience was a bad ECU
Old Jun 1, 2008 | 08:12 AM
jmccalip's Avatar
Default Re: (TheMuffinMan)
But it's only solid when I test for codes. If it was bad, wouldn't it be solid all the time?
Old Jun 1, 2008 | 09:22 AM
Default Re: (jmccalip)
If it's only solid when you have the two pin connector shorted it means that there are no codes stored as I previously posted.
Old Jun 1, 2008 | 10:03 AM
jmccalip's Avatar
Default Re: (GhostAccord)
Ok, thanks! Just making sure.
EJ6_OB
Apr 16, 2012 05:38 PM
kobeRy_si
Honda S2000
Mar 29, 2006 12:35 PM
khmboostedeh2
Mar 18, 2005 07:09 AM
boostin4door
Jul 1, 2004 11:58 AM
fourdoorsleeper
Nov 4, 2003 07:12 PM
