Troubleshooting for uberdata
Old Mar 17, 2005 | 06:19 PM
khmboostedeh2's Avatar
Default Troubleshooting for uberdata
hey, i guess search is down or something but its not working for me, and ive been searching throu ecimulti.org with no success.
first off i chipped my ecu (p75 b18b), made a basemap, made the safe presets for boost and ign(110, .8), and just now was the first time i started the car. It threw teh CEL (which i havent checked), and shut off immediately. I restarted it and it stayed on until i lightly tapped the gas and it almost shut off again.
so my questions is, should the solders be bad, would the car even start? of the symptons ive briefly explained is there any obvious problem?
thanks in advance,
kris
Old Mar 17, 2005 | 06:44 PM
SOHC_MShue's Avatar
Default Re: Troubleshooting for uberdata (Jeterkm02)
post your question on the uber forum
93turbo16's Avatar
sounds like a chipping or basemap problem. But yea, post it there with pics of you soldering.
Old Mar 18, 2005 | 07:02 AM
Default Re: (93turbo16)
thanks for responses... anyone else?? uber forums are so slow.
when i went to check the CEL... it was a solid CEL.
Old Mar 18, 2005 | 07:09 AM
93turbo16's Avatar
Default Re: (Jeterkm02)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jeterkm02 &raquo;</TD></TR><TR><TD CLASS="quote">thanks for responses... anyone else?? uber forums are so slow.
when i went to check the CEL... it was a solid CEL.</TD></TR></TABLE>
Yea, if you would read up on the forum, instead of waiting for questions to be answered, I know, that isn't how it should work.. but that is how it does work over there. Since it is a kind of DIY thing, reading will help you out. The LS bin is corrupt, to get around it you can copy and paste the fuel and ignitino values into a GSR bin and then turn off vtec and knock sensor. Also it would be nice if you scaled the RPM to to match the LS.
Well the scalars aren't off that much, so it should be ok.
hucoreyCRX
Jun 29, 2009 05:39 AM
jmccalip
Jun 1, 2008 10:03 AM
Kobal
Dec 13, 2007 08:42 PM
b17eg
Sep 17, 2007 08:25 PM
swappedcx
Feb 16, 2006 10:38 PM
