engine light on
Old Nov 30, 2005 | 07:48 AM
jizzer671's Avatar
Default engine light on
alright when i turn my car on the check engine,lights up then flashes 10 times, then disappears. i jumped the two terminals under the dashboard to read the trouble codes but, no flashes to read. i looked up the 10 flashes and the indicator codes are telling me its the (intake air tempeture sensor) is this correct. im not sure because i was unable to jump the terminals.
Old Nov 30, 2005 | 09:31 AM
shamoo's Avatar
Will you make something up for me please?
Default Re: engine light on (valve timer)
Are you sure it's the "Check Engine Light" and not the Maintenance Required Light? The CEL light won't blink unless it's jumped already. It will stay on solid.
The Maintenance Required Light will initially blink upon startup. After a few hundred miles, it will stay on solid until it's reset by you or the dealer. It's just there to remind you to do normal maintenance such as oil changes, fluid top-offs, etc. It comes on automatically after about 7500 miles or so.
TommyEp3
Jun 4, 2013 12:14 PM
BiggieBert
Acura TL, RL & ZDX
Sep 20, 2008 08:59 AM
fuzzymemoforshow
Honda Civic (2006 - 2015)
Oct 21, 2006 08:04 PM
pens81
Acura TSX
Mar 30, 2006 03:42 AM
under_psi
Aug 16, 2001 12:50 PM
