check engine light
Old Jan 10, 2007 | 10:51 AM
soon2bdropped's Avatar
Default check engine light
okay well its a 95 honda accord ex 5spd. well a few days ago i replaced the rack an pinion.. and we took out the o2 sensor so we can drop down the rack.. well we put it back and after installing the rack we immediately get a check engine light.. i'm like wtf.. so we play around.. disconnect battery. ecu fuse still comes on..pulled the code i'm getting code 41 and 43
41 oxygen sensor heater and 43 fuel supply system.. whats going on here.. do i need a new o2 sensor and is it alright if i buy it used from junkyard or what?
whats going on here,.
Old Jan 10, 2007 | 11:19 AM
Homesickelian's Avatar
Default Re: check engine light (soon2bdropped)
getting it from a junkyard might be sketchy business cause you don't know how old it is and what it's been through laying in the yard. They aren't overly expensive so I'd highly recommend getting a new one. Dont get Bosch of course...
Old Jan 10, 2007 | 11:48 AM
TheMuffinMan's Avatar
He knows where you live!
user from a junkyard should be ok, or hit up like napa or advance
Old Jan 10, 2007 | 02:24 PM
ex95cord's Avatar
yah just spend the money for a new one...when it comes to sensors I don't like to go used, hopefully that will fix both codes....good luck
Old Jan 10, 2007 | 08:59 PM
Default Re: (ex95cord)
but what i don't get is that why does the check engine light pop up after we uninstall the o2 sensor and put it back.. honda must made a way that whenever u remove the o2 sensor.. to make the sensor go faulty.. has to be.
also is both codes related to bad o2 sensor?
Old Jan 10, 2007 | 09:05 PM
NJ VTECpowered's Avatar
Default Re: (soon2bdropped)
your 02 is probably bad
Old Jan 10, 2007 | 10:52 PM
Heinekenf22's Avatar
yea u probably accidentally touched the head of the o2 sensor. if i were you i would just get a new one. i wouldn't trust o2 sensors from junkyards. i'm not sure if this affects you or not. but i remember i went to the honda dealer a while ago and they told me that my car was on emissions waranty or something. and it covers all check engine light including o2 sensors. so maybe you should check if u got that warranty on your car.
Old Jan 11, 2007 | 07:23 PM
Default Re: check engine light (Heinekenf22)
will driving with a bad o2 sensor prematurely wear out the engine.. or even make carbon build up?
Old Jan 11, 2007 | 07:32 PM
I don't think it will be that hazardous. Prolonged it can, from what I know but the biggest deal is gas mileage and car performance...
It messes up your oxygen/fuel mixture
Here's a good explanation..
http://auto.howstuffworks.com/question257.htm
Old Jan 11, 2007 | 07:38 PM
sony224422's Avatar
Default Re: check engine light (Homesickelian)
it doesn't matter if you touch the head of it. Are you sure its all connected right and in tight? I bought a used one off here from someone for like $30 and it works perfectly fine.
BTW i drove around for probably 4 months with the light on, and all it did was kill my acceleration and a little on my gas mileage. But it might have just been on its way out, mine randomly came on when i was driving.
Old Jan 11, 2007 | 10:20 PM
ex95cord's Avatar
yes both codes are related to the O2...get a new one and you'll be set. and make sure you reset the ECU
Old Jan 12, 2007 | 04:45 PM
thanks guys..
WhiteXHysteria
May 1, 2012 01:23 AM
scspeed
Jan 27, 2010 06:33 PM
jayrod7
Jan 21, 2010 01:45 PM
Matt00
Oct 10, 2005 10:41 AM
civic_boi
Mar 28, 2004 03:06 PM
