HELP!: 95 integra code 41 Check engine!
Old Jan 23, 2010 | 12:57 PM
scspeed's Avatar
Default HELP!: 95 integra code 41 Check engine!
It says its the oxygen sensor heater, ok which one?? It doesnt tell me which o2 sensor is teh bad one so i dont really know what to do...
I tryed reseting the code by disconnecting a terminal from the battery but the code is still there...
The car also runs totaly fine when cold but once raelly warm it begins to spit and sputter when at more than 50% and mostly at lower rpms... Could a bad o2 sensor cause this??
Old Jan 23, 2010 | 01:15 PM
mrdeadman's Avatar
They let me pick
Default Re: HELP!: 95 integra code 41 Check engine!
Code 41: Primary oxygen sensor heater
I would guess that it is the primary o2 sensor, before the cat...
Old Jan 24, 2010 | 07:18 AM
scspeed's Avatar
i see, so would that be the 1st o2 sensor coming from the dp? and could that make it spit and sputter really that much once the motor gets warm?? I just hope im doing the right thing to fix this, its $88 and if i dont need it i really would rather not buy it...
I also find it weird that with trying to reset the ecu by disconnecting the battery the light still stays on..
Old Jan 24, 2010 | 12:19 PM
robcivic559's Avatar
my car sound like the same thing my teg wont go past 3500 rpm if it the sensor or the fuel fillter my check engine light is on i might of hit or damage the that sensor when changing the streering rack
Old Jan 24, 2010 | 07:48 PM
mrdeadman's Avatar
They let me pick
You have to disconnect the battery for at least 15min to clear everything.
If your car is 96 or later you can swap the primary and secondary o2 sensors after to clear the code, and then see if the code for the secondary o2 pops up. Then you will know that it is the o2 sensor that is causing the problem for sure.
Old Jan 25, 2010 | 04:11 PM
scspeed's Avatar
cool great man thanks alot! i will do that!
Old Jan 25, 2010 | 05:37 PM
follie gatts's Avatar
a 1995 only has one oxygen sensor
Old Jan 25, 2010 | 05:56 PM
HondaPartsHero's Avatar
Technical Hero
https://honda-tech.com/forums/hybrid-engine-swaps-18/%5Bfaq%5D-%22my-vtec-doesnt-work%22-1812135/
halfway down the page is the troubleshooting for code 41 for OBD1
Old Jan 27, 2010 | 06:33 PM
i clear the code i had a code 16 it was the fuel injectors so i throw some fuel injector cleaner so it run cool i get pass 3500 i didn't mess with the 02 sensor i might have hit the sensor when installing the streering rack but the check engine light has come back what do should i change the 02 sensor any way and was the fuel injector the reason for not going pass 3500 rpm
got 95 gsr
Zac W.
May 15, 2012 08:22 AM
crx2hatch
Feb 10, 2011 06:30 AM
crxtreme27
Sep 19, 2002 02:01 PM
neumonik
Sep 3, 2002 06:42 AM
89Si
Apr 21, 2002 07:24 PM
