Can you swap 89 Accord /87 Prelude Trannys'?!?!?!
HELP!!!!!! PLEASE!!!!!!!!!! can you swap out and 89 Accord trans. over into an 85 Prelude?????? My Trans went out in the Prelude and I have a friend that has an Accord sitting around with a bad engine. Is this swap able to be done so I can get my car back on the road <U>ASAP!!!!</U> Like Tomorrow ( Mon. the 16th?) MY has been broken till I this out.
Thanks!!!!!!!!!!!
Thanks!!!!!!!!!!!
Re: Can you swap 89 Accord /87 Prelude Trannys'?!?!?! (z-partsman)
Yes, it should be a direct swap. Check out http://www.3geez.com/showthread.php?s=&threadid=165 for a little better explanation. It's for a Prelude to Accord tranny swap, but the opposite should also work the same. The gear ratio's will be a little different though
