fuse!
Old Jan 7, 2007 | 10:20 AM
Sic_DA_Nine's Avatar
Default fuse!
sorry..i posted in electrical but thought id
had more of a chance getting replies here
car: 1991 Acura Integra LS SE
problem:
deck stop working and clock stop working...
* found out that me cig lighter, clock, interior light fuse was blown (fuse 14)
it was a 10 fuse.....
so i got another 10 fuse and tried to put it in..
fuse blew when touched...
tried a 15 fuse....
question is...should i try a higher fuse?
what should i do?
imma be driving a 6hr drive soon and i need my radio working and stuff
Old Jan 7, 2007 | 11:26 AM
dc5_integra's Avatar
Default Re: fuse! (Sic_DA_Nine)
No dont get a bigger fuse. Thats what alot of people think that you should do but all that will do is set your car on fire because its no enough amps to blow the fuse. You have a short to ground somewhere.
Old Jan 7, 2007 | 11:31 AM
DC2 Mang's Avatar
You actually have a short to ground on the power side one of the wires
do not stick a higher amperage fuse in the fuse box, you risk the chance to melting your wiring
there is a short in your wiring causing the fuse to blow, so unless you are confident in reading wiring diagrams and using a DVOM take it to an electrician to he can fnd the problem
Old Jan 7, 2007 | 11:41 AM
Default Re: fuse! (DC2 Mang)
Old Jan 7, 2007 | 11:53 AM
when i plug in the tail light harness on the driver side..it seems to blow..
its the fuse on the farthest to the end...
Old Jan 7, 2007 | 12:12 PM
Default Re: (Sic_DA_Nine)
ok so it is shorting somewhere in your taillight circuit. check all the wires in the taillight circuit and make sure none are worn through or frayed.
Old Jan 8, 2007 | 09:49 AM
Default Re: (dc5_integra)
will do...but does anyone know what that harness is?
my tail lights seem to work without that harness
Old Jan 8, 2007 | 09:54 AM
DC2 Mang's Avatar
check a wiring diagram, the clock, cigarette lighter and radio are all wired in a parallel circuit meaning they all recieve power throguh one wire
check al the connections on that wire as well and the power wire leading to each item for rips or tears
ot may require you to pull the dash off to check the wiring but it should not be too hard to spot
thomaswjparker
Mar 24, 2014 06:59 AM
Hanmin
May 16, 2008 02:17 AM
LUDE21
May 31, 2007 01:52 PM
Sic_DA_Nine
Audio / Security / Video
Jan 7, 2007 11:04 AM
