Automatic transmission downshift problem
1995 Accord with an automatic transmission. It randomly downshifts and stays in low gear so the rpms are high. What could be the problem? Could the ecu just need to be reset?
Could be a sticking throttle valve inside the transmission. When throttle pressure overcomes governor pressure the transmission downshifts. When governor pressure overcomes throttle pressure the transmission upshifts.
Are you pushing on the throttle when the car downshifts?
is there an easy way to fix this problem because im having thee same problem on my automatic 91 integra ls it only started after i put new tranny fluid in tho a fast reply would be great cause i am moving soon and need the car to do so thanks
cadeMFjohnson
Aug 5, 2009 12:57 AM
WAFFLES
Apr 25, 2003 01:42 PM
