another starting problem....
Old May 21, 2003 | 07:30 PM
aengnr1's Avatar
Default another starting problem....
I think im having almost the same problem as a few others here, but I havent found an answer yet........my 94 will USUALLY start without a problem...but once in awhile it will crank over, breifly start, and then die....in which time i have to sit for about 30 seconds before i can try to turn the key again and then it usually starts. (if i keep cranking, nothing will ever happen and i will sit there for an hour) Since i have to wait, im assuming that its getting flooded, so fuel is not the problem. I just replaced the plugs/cap/rotor/wires and air filter last week, and that didnt solve anything either.....Im thinking coil but i havent gotten off my *** to check it with an ohm meter.....any other ideas???????
Old May 21, 2003 | 07:36 PM
iam7head's Avatar
Default Re: another starting problem.... (aengnr1)
https://honda-tech.com/zerothread?id=512482
please read this first..
My car did the samething when my alternator starting to die
Old May 23, 2003 | 06:25 PM
DragonTLS's Avatar
get a new main relay
Old May 24, 2003 | 06:14 PM
aengnr1's Avatar
Default Re: another starting problem.... (KTLS)
im searching through the factory service manual in the ignition/electrical and cant find the "main relay" what am i supposed to be looking for? thanks...
pootie.teng
Jul 31, 2008 10:37 AM
prophetjinn
Apr 28, 2006 12:24 AM
eric416
Jul 15, 2005 11:39 AM
kitkatR
Oct 31, 2004 07:15 PM
Tony R
Jun 15, 2004 07:09 AM
