Problem starting when hot
Old Oct 26, 2004 | 01:33 PM
kitkatR's Avatar
Default Problem starting when hot
Ok I am going crazy, for the past oh two years or more I have had the same problem and nobody to this day can figure it out. When my car gets hot either from driving or just sitting in hot weather it gets vary hard to start. It tries to turn over but only after a couple mins and me giving it a little gas it starts. I never once had this problem when the car has been sitting inside.
This only started when I modded my car and I tried almost everything to fix it. I took off the MSD changed the plugs, wires, fuel filter. I just don't get it, the only other thing I can think of is getting a new radiator but i don't want to waste the money if it wont help this problem.
Any advice is welcome please! Thanks
PS Now that I live in Texas I REALLY need to get this fixed due to the hot *** weather.
Old Oct 26, 2004 | 01:36 PM
Chris93Si's Avatar
Default Re: Problem starting when hot (kitkatR)
Dude it's sooo your main relay.
Car won't start when it gets hot inside but if you let it sit for a couple minutes it'll start right up right?
Yep, like $50 for a new one and simple switch, it's up under your dash.
Old Oct 26, 2004 | 01:41 PM
kitkatR's Avatar
Default Re: Problem starting when hot (Chris93Si)
witch kinda shop can fix that? I am new to my area so i have to go to an unfamiliar place.
Thanks
Old Oct 26, 2004 | 01:43 PM
Chris93Si's Avatar
It's just a fuse up under your dash, go pick one up from your local Honda dealership take the old one out and plug the new one in.
It's a pretty common Honda problem, no biggie at all, 5 min fix
Old Oct 26, 2004 | 01:45 PM
kitkatR's Avatar
thanks! but can you explain why this only happens when its hot and why it only happened after I modded (jun 3's, hondata, ect)
Thanks for the help
Old Oct 26, 2004 | 01:47 PM
B2FiNiTY's Avatar
Sounds like main relay. Tons of crx people have had this problem.
Old Oct 26, 2004 | 02:03 PM
kitkatR's Avatar
Default Re: Problem starting when hot (B2FiNiTY)
You guys might not know this but will honda have the part? Or do I have to go to acura, this might save me a 45 min drive.
Old Oct 26, 2004 | 02:07 PM
B2FiNiTY's Avatar
You can have honda look up the acura part and cross check it to see if there is a same honda part available by part number.
OR, just call
Old Oct 28, 2004 | 05:15 PM
kitkatR's Avatar
AHHHHHH I just changed the main relay and the same things is still happening, car gets hot try to start it and it has a very hard time getting going. Some black smoke comes out of the back and this only happens when hot.
Please anymore ideas thanks
Old Oct 28, 2004 | 05:20 PM
chad's Avatar
Moderator
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B2FiNiTY &raquo;</TD></TR><TR><TD CLASS="quote">You can have honda look up the acura part and cross check it to see if there is a same honda part available by part number.
OR, just call </TD></TR></TABLE>
honda and acura's use the same main relay.....
Old Oct 29, 2004 | 08:15 AM
kitkatR's Avatar
Default Re: Problem starting when hot (chad)
anybody?
Old Oct 29, 2004 | 10:28 AM
Chris93Si's Avatar
I'm stumped, I was sure it was the main relay.
Somebody help this guy out
Old Oct 29, 2004 | 11:34 AM
5 Lug's Avatar
Sounds like some sort of connection problem (obviously) with maybe the ignition or starter or something. I had aftermarket power windows in my previous car and after sitting in the sun and getting hot, the passenger one wouldn't want to work, I'd have to smash the button down. Same with alarm key pad switch inside my car, if it's hot one of the buttons didn't work until the inside cooled down. Somebody told me that when it gets hot, the heat expands the connection so they don't make contact like they should, or very little contact. Sounds like that might be the problem for you also, but what connection isn't being made is beyond me.
Old Oct 29, 2004 | 01:29 PM
houston's Avatar
Default Re: Problem starting when hot (5 Lug)
black smoke means its getting fuel.. so presumably you have a spark issue?
got any friends? try swaping ECU's? you have already done the other ****.
My first thought was the cat.. but since it happens even if you haven't driven it in a while.
Enjoy that Tejas heat
Old Oct 29, 2004 | 03:49 PM
vtec.dc2's Avatar
whats your ecu setup? obd1?
Old Oct 29, 2004 | 05:58 PM
The $hop inc.'s Avatar
I would check your fuel pressure might be too high or your regulator is bad ,your map sensor might be reading the wrong readings and check your timing....hard to say but if your in the South Houston &gt; Pasadena Area come by the shop and I can check it out for you.....
Old Oct 31, 2004 | 08:35 AM
cjames235's Avatar
Default Re: Problem starting when hot (TeamSSR)
im pretty sure i know what it is....... try this...... on the firewall right in the center above the prop. valve is a little black box with a couple hoses that go to it........ un-plug the plug that is on the front of that...... if you need a pic i can show you what it is on my car...... i had these same issues on my old 97 ex civic when i converted to obdI..... found out it was that and i unplugged it and never had the problem again im converted to obdI now on my R unplugged it from day one and have never had a problem........ it has something to do with the emissions and causes that to happen
try that and lemme know if thats the problem
-chris
Old Oct 31, 2004 | 08:55 AM
kitkatR's Avatar
Default Re: Problem starting when hot (cjames235)
thanks for the replies, yes I would like a picture to see what you are talking about.
Also it is a obd 1, I have hondata 3 and also a aem fpr if it matters.
thanks
Old Oct 31, 2004 | 10:47 AM
ITR184's Avatar
Is your timing advanced? If so, perhaps you are running to much advance.
Old Oct 31, 2004 | 01:33 PM
Madspeed's Avatar
Default Re: Problem starting when hot (Cod Sac)
bump for this dude.....cause i would like to know the deal myself.....i would have definitely said the main relay....but obviously thats not it.....help this dude!!!!
Old Oct 31, 2004 | 04:01 PM
cjames235's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kitkatR &raquo;</TD></TR><TR><TD CLASS="quote">thanks for the replies, yes I would like a picture to see what you are talking about.
thanks</TD></TR></TABLE>
here is your pic...... unplug the circled peice and see if that fixes your problem
-chris
Old Oct 31, 2004 | 05:17 PM
icefire069's Avatar
Do you have any problems when your driving the car and all the sudden it just shuts off on you with no power in your dash boards but ac and radio are ok? Just curious......
Old Oct 31, 2004 | 07:09 PM
vtec.dc2's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cjames235 &raquo;</TD></TR><TR><TD CLASS="quote">
-chris</TD></TR></TABLE>
yep.. i had this problem and it went away as soon as i unplugged that piece.. basically, with your setup, fuel vapors go into IM from gas tank and messing up the idle. this will make sure that the valve will stay shut during startup.
it has nothing to do with relays or failure of any unrelated parts
Old Oct 31, 2004 | 07:15 PM
esponet's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chris93Si &raquo;</TD></TR><TR><TD CLASS="quote">
It's a pretty common Honda problem, no biggie at all, 5 min fix </TD></TR></TABLE>
what he says.
brezuno
Jun 29, 2010 01:47 AM
pootie.teng
Jul 31, 2008 10:37 AM
hydroflip
Jul 7, 2007 03:45 PM
Tony R
Jun 15, 2004 07:09 AM
dsolberg
Aug 13, 2001 02:06 PM
