AFC Hack Check Engine Codes
Old Jul 31, 2004 | 06:41 PM
jmal1919's Avatar
Default AFC Hack Check Engine Codes
Those with the f23, does anyone get the check engine light often? I'm getting 3 everytime boost builds. The codes are:
Mass Airflow sensor
Running Too Rich
Cant remember the last one.
I will try and get the exact codes tomorrow when I go to get them cleared again.
Today, code P1106 "Fuel Air Metering" was read today. Whats up?
Only running 6lbs, and it has been tuned.
Modified by jmal1919 at 3:08 PM 8/1/2004
Old Jul 31, 2004 | 09:34 PM
Atheist's Avatar
Nope, I get none on my f22. What #s are you running?
Old Jul 31, 2004 | 10:46 PM
honda9369's Avatar
Default Re: AFC Hack Check Engine Codes (jmal1919)
Old Jul 31, 2004 | 11:31 PM
Nick H's Avatar
New User
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jmal1919 &raquo;</TD></TR><TR><TD CLASS="quote">Those with the f23, does anyone get the check engine light often? I'm getting 3 everytime boost builds. The codes are:
Mass Airflow sensor
Running Too Rich
wait, f23's use a MAF instead of a MAP? are you sure about this?
Old Aug 1, 2004 | 06:56 AM
jmal1919's Avatar
Default Re: (Atheist)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Atheist &raquo;</TD></TR><TR><TD CLASS="quote">Nope, I get none on my f22. What #s are you running? </TD></TR></TABLE>
bout -35%
Modified by jmal1919 at 10:29 AM 8/2/2004
Old Aug 1, 2004 | 06:57 AM
jmal1919's Avatar
Default Re: AFC Hack Check Engine Codes (Nick H)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Nick H &raquo;</TD></TR><TR><TD CLASS="quote">wait, f23's use a MAF instead of a MAP? are you sure about this?</TD></TR></TABLE>
pretty sure, but will write them down today.
Old Aug 1, 2004 | 10:31 AM
brads94accord's Avatar
im pretty sure you have a MAP sensor. how much boost are you running? because anything over 11 lbs through the stock MAP sensor will throw a CEL. have you had the AFC tuned yet? if not, you might wanna throw it on the dyno and hook it up to a wideband to get some accurate A/F ratio numbers.
Old Aug 1, 2004 | 11:07 AM
jmal1919's Avatar
Default Re: (brads94accord)
The code pulled off today is P1106 "Fuel Air Metering"
And my AFC was tuned and am only running 6lbs.
Shoalin R
May 21, 2010 01:42 PM
bugster
Mar 2, 2007 06:14 PM
kaoss_11
Sep 10, 2006 04:14 PM
kaoss_11
Sep 10, 2006 12:03 AM
