advice on clutches
Old 10-15-2009, 02:00 AM
wesk18's Avatar
Default advice on clutches
i was wondering what clutch kit as excellent peformance n to buy?
i've seen some in ebay an xtr they have 3 different stages.
Old 10-15-2009, 05:59 AM
bseriescrxsi's Avatar
Default Re: advice on clutches
what do you have done to your car that you would want more then even a stage 1...instead of just a 4 puck stock replacement
Old 10-15-2009, 10:02 AM
GhostAccord's Avatar
x2
What are your mods? What is the car going to be used for? What are your Hp goals?
Old 10-15-2009, 10:17 AM
reaction360's Avatar
I've never used one of those ebay xtr clutches, but we've seen some people come through the shop with them and did not have much luck even on NA cars haha. They were there to buy better clutches.
I have just a cheap oem replacement clutch in mine. been good to me for about a year now. My f22 is pretty stock with just bolt ons but i do beat the crap out of it
Old 10-16-2009, 10:31 PM
wesk18's Avatar
yea i was thinking of stage 1 or 2 something better than stock to feel a slight difference from oem to aftermarket.
i currently have headers, aem intake on it, going to chip the ecu, and maybe change the cam gear n camshaft(bisi).
not intending to race or anything just want my car to be somewhat fast.
Old 10-17-2009, 04:57 AM
be professional
Targa250R's Avatar
A clutch doesn't make your car faster unless your current clutch is worn out or slipping under massive torque applications. Considering that you aren't making much if any more torque than a stock engine (which you aren't unless you forgot to tell us about the high-boost forced induction and the nitrous oxide), installing a clutch with a higher friction level and clamping force will only make the car more of a pain in the *** to drive and transmit more shock to the drivetrain, in addition to making your wallet lighter.
If you like driving in traffic with a clutch that works like an on/off switch and breaking engine mounts and differentials, then by all means get the clutch with the highest "stage number" (what a joke those are) and snazziest marketing buzzword name that you can find.
If you wanted to make the smartest move, you'd get an Exedy/Daikin OE replacement clutch kit, or an Exedy Racing organic kit at the most. Exedy/Daikin is the most trusted name in import clutches and is relied upon by most Japanese auto manufacturers to make OE clutches - there's a reason for that.
When replacing the clutch, you'll need a new friction disc, pressure plate, and release bearing. Don't forget to have the flywheel resurfaced at a local machine shop if you aren't replacing it.
Old 10-17-2009, 06:58 AM
AndyD's Avatar
If that's the case, I recommend an OEM Exedy replacement clutch.
Old 10-17-2009, 09:14 AM
uberEFtuner's Avatar
I did a stage one clutch with a light weight flywheel. The flywheel was big mistake. Perhaps on a dyno it would put out more HP but it killed my torque. The stage one clutch is nice, it just feels nice and tight. I bought my kit from AIM clutch co. I,m happier than a pig in shi*
As far as ebay sales go: 1. Only buy from someone with 95% and higher feed back
2. Read feedback and see if the negative are comments about crappy product, or if some idiot is complaining about how something looks etc.
3. Make sure the part isn't $10 AND SHIPPING IS $100
4. Make sure they are an authorized dealer
Old 10-17-2009, 09:52 AM
P_Adams's Avatar
Wes:
I'd take a few hours and research what's offered thru reputable web based stores before I would commit to an EBay purchase. Pay particular attention to the brands they offer. If you can find one of the "National Brands" on an Ebay site, THEN I'd consider it.
There's a lot of "Private label' stuff on EBay which you don't see elsewhere.
Often, this is repackaging of obsolete (Last seasons) stuff no longer in production. In worst cases, these are kits (clutch kits in this case) cobbled together with parts from different manufacturers.
All I'm suggesting is "Buyer Beware"
If you're intended purpose is a mild performance boost, I'd avoid the biggest baddest selection available. You don't need the heavy clutch application pressures and the associated leg cramps that come with it.
I'd also suggest having the flywheel surface ground to eliminate high/hot spots and to avoid chattering complaints.
P
Old 10-17-2009, 10:01 AM
be professional
Targa250R's Avatar
There is also a high incidence of counterfeit product being sold on eBay. Exedy released a guide to aid in spotting a fake Exedy/Daikin clutch, and it's rather frightening how close in appearance that the fakes are to the genuine article.
Old 10-17-2009, 10:05 AM
P_Adams's Avatar
Totally agree. And the insidious part of all this is you can't inspect the packaging until you've got it in your hands.... and then it's too late.
"Let the Games Begin" will be the mantra when you attempt to return it
P
Old 10-22-2009, 04:04 PM
Janet@bisimoto's Avatar
Like into Action Clutch. There manufactured in the U.S.
808k20a2
05-22-2011 07:21 AM
redb16coupe
12
02-11-2009 06:16 AM
SLEEPER775
08-25-2008 11:21 AM
vti444
22
02-02-2005 02:22 PM
igo4bmx
03-27-2003 10:05 PM
Quick Reply: advice on clutches
