Accord v-tec to non-v-tec swap
Accord v-tech to non-v-tech swap
I have a 94 honda accord Ex v-tec and the motor is bad. It is my girlfriends car. Iwant to go to the f22b2. I found one in a 97 lx with 112,000 miles. I was wounting to know if the wiring harnes is the same and would i need to change comp?
Thank u
Thank u
H-T Order of Merit
Re: Accord v-tech to non-v-tech swap (20crx)
the engine harness is pretty much the same I belive with the addition of the v-tec wires in the F22B1 engine harness. I'm not completely sure though.
I'm also pretty sure you would need the F22B2 ECU as well.
I sent you a PM, you won't be able to respond to the PM so if you're interested, just send me an email to the email I listed in the PM.
Re: Accord v-tech to non-v-tech swap (TouringAccord)
Thank u for your info. I tried to find the PM but I dont know what that is and where. If u could let me know that would help. I am geting the motor tomarrow. I will let u know how it gose. If u think of any thing else let me know. Thanks Man
20crx
20crx
H-T Order of Merit
If you have a pop-up blocker on then you probably won't see it. Just go to your profile in the upper right of the site, then click on Instant Message History. You'll find it in there.
Hey I will just give u my e-mail address and u can e-mail me. Its trvs_gray@yahoo.com.
ate my pixel
1 Post
I'd recommend using the F22b2 ECU with the motor, just because it's a SOHC whereas the F22b1 is DOHC with vtec. If you try to keep the same ECU it's definitely going to throw some CELs because of the vtec not being hooked up, best case scenario.
Re: Accord v-tech to non-v-tech swap (accord2021)
The F22B1 is not a DOHC VTEC, its a SOHC VTEC
the H22 is a DOHC VTEC
but yes you would want to use the F22B2 ECU as it would be better able to run that engine.
JapDreamin
04-24-2018 12:01 PM
