Accord pin outs
Accord pin outs
Sorry this is a request. I知 googling for pictures of a pinout for pt6 but an obd1 integra pictures often pop up. I need three ecu pins to be donated for another purpose. I checked the faqs idk if I maybe missed it.
Premium Member
Re: Accord pin outs
All of the OBD1 pinouts are very similar. The Accords had a few pins swapped from the standard Civic/Integra stuff but it's nothing you can use for another purpose anyway.
Re: Accord pin outs
These are no different than a pt3 in terms of pin out. Im not sure what you're hoping to gain on other pins though. Most of these early obd1 ecm were pretty basic units taking sensor info into consideration while keeping the engine from being damaged
Re: Accord pin outs
I have a code for the tps popping up with a brand new wire harness annnnd tps sensor. So I cut the tps sensor connector off the old harness and soldered three wires to it. I知 going to bypass the right shock tower connector and see what happens. I was thinking pins from the radio or cruise control circuits. I want to use three pins from my donor Cb7. Instead cuting the three existing for that circuit. Just in case that doesn稚 solve my problem.
What i have to gain?
my car will run and I can drive it.
MPower332TI
06-18-2003 01:18 AM
