IAT Sensor question
I have a 97 civic with an obd2a to obd1 conversion harness. I am going to have it tuned with Neptune and a po5 ecu. I have an Edelbroke IM with an obd1 IAT sensor already mounted. My question is how should I wire the IAT sensor? Which wires go to which prongs? And should I get a pigtail harness for it?
Modified by sohcT at 11:41 AM 3/12/2006
Well, i would try and find the sensors hookup from a factory harness. Then look in a shop manual, even the cheapy ones work. Look up the ecu diagram and see what two pinouts use the iat sensor and wire it up directly. Now, i do know that when i had a short on one of those wires my ecu was telling me that i had a bad o2 sensor.... so i believe they may be intertwined.
If you don't mind, what did you do to run the po5 computer? or have you not yet, i tried a jumper harness, but i'm assuming you need to run an obd1 throttle body and what not, cuz my car wouldn't run for crap.
okay i see what you want now. I looked in my books, wiriing diagrams and from what i'm seeing. The obd1 is a red/yellow and a green/white wire. The red yellow goes to the computer, and the green/white goes to a junction connection.
obdII red/yellow, and green/black. Same thing, red/yellow to the computer, and green/black to junction connection. So, if the plugs are the same, plug it in, otherwise you'll have to do some soildering.
Yuenglinger Hatchbacker
Mar 6, 2006 09:45 AM
