96 accord non-vtec
Old 09-07-2010, 07:54 AM
sohczc91's Avatar
Default 96 accord non-vtec
Good afternoon Honda-Tech,
I just wanted to say great forum keep up the good work everyone. I have been having problems with my accord throwing some codes 0450 and 0453 I think and will check and correct.
Scanner says something like evap emission control solenoid pressure high. I have replaced the charcoal canister and both solenoids and am still having the same codes come back.
Has anyone ever seen this or had the same problem.
Someone Please Help!!
Thank You
Dave
Old 09-07-2010, 09:26 AM
F20B_accord's Avatar
Default Re: 96 accord non-vtec
try resetting ecu?
Old 09-07-2010, 09:48 AM
GhostAccord's Avatar
It could be that the pressure release in the gas cap isn't working. If resetting your ECU doesn't remove the codes permanently. Try replacing your gas cap.
Old 09-07-2010, 11:39 AM
sohczc91's Avatar
Originally Posted by F20B_accord
try resetting ecu?
Tried it just keeps coming back same code beginning to think the ecu is bad
Old 09-07-2010, 12:58 PM
Those two codes have to do with a problem with the evap system pressure. What two solenoids did you replace? There are two valves, 1 solenoid and a pressure sensor in the EVAP system. Did you replace the vent pressure sensor? (37942-P0H-L01)
Two way Valve - 17371-SV4-L31
Canister Vent Shut valve - 17310-SV4-L32
Valve set Solenoid - 17012-SV4-L30 (L31)
Vent Pressure Sensor - 37942-P0H-L01
Remove your fuel fill cap, reset the ECU and start the car. If the code does not return, replace your fuel fill cap. If it does return test/replace the Vent pressure sensor.
popsep3
08-14-2019 10:24 AM
Staska
04-23-2016 03:25 AM
Crippled Eagle
12-16-2015 10:31 AM
sirmugenpower
10-27-2009 05:16 AM
Phat_Jax
04-08-2005 11:29 AM
Quick Reply: 96 accord non-vtec
