94 accord won't start oil and battery lights stays on
Old 05-30-2016, 10:51 PM
hondamyheart's Avatar
Default 94 accord won't start oil and battery lights stays on
Hi,
My accord won't start , the engine is turning over but not starting the oil and battery lights stays on, it just happened yesterday when I start it it blows white smoke for 30 seconds and then stopped , the car was running rough and backfiring like hell. I shut the car off and now it won't start the oil and battery lights stays on only . What could cause this?
Old 06-01-2016, 02:11 PM
fcm
Old Fart
fcm's Avatar
Default Re: 94 accord won't start oil and battery lights stays on
White smoke is coolant burning,= blown head gasket. 94
Old 06-12-2016, 11:29 PM
am in process of removing the head. I removed valve cover, set engine to TDC and removed timing belt, removed cams and distributor.now I gained the access to the head bolts they are b**** to remove. Any tips on how to break them loose?
Old 06-13-2016, 10:09 PM
I managed to remove them with breaker bar. I just need to unbolt the thermostat neck and vtec solenoid.
Old 06-14-2016, 12:29 AM
holmesnmanny's Avatar
Did you atleast compression test before you decided to pull the head ?
Old 06-14-2016, 02:01 AM
Yep, All zero! makes me surprised.
Old 06-16-2016, 03:53 AM
It's practically impossible to have no compression on all cylinders, did you actually check tdc or just set the crank or cam to tdc before you pulled the belt, without checking that they were all lining up ?
Old 06-17-2016, 04:25 AM
Pulled up the head. Head gasket shot, Pistons filled up with water and oil. How do I know if the pistons are bad?
Old 06-18-2016, 01:10 AM
It's likely your car was overheating for a long time. There is a lot of corrosion and burned oil in there.
Old 06-18-2016, 03:42 AM
I took the head to the machine shop ,they checked and serviced it. It is fine. The car was sitting for a long time around two years. when i pull the dipstick the oil was dark black. Image of headgasket attached
cali.newguy
09-12-2017 10:44 AM
hondamyheart
06-19-2016 10:29 PM
SamC
01-07-2010 08:00 AM
x1N5AN3x50ULJAHx
10-04-2009 09:58 AM
vtec69
01-16-2003 07:07 AM
Quick Reply: 94 accord won't start oil and battery lights stays on
