1998 accprd replacement engine stalling under throttle help!
Old Sep 5, 2010 | 08:59 PM
Hondapreludeg's Avatar
Default 1998 accprd replacement engine stalling under throttle help!
I have a 1998 Accord with a 2.3 4 cyl motor. Just finished throwing a junk yard used motor in it. I did the timing belt and valve adjustment out of the car. Got it back in and it stalls when you give it throttle. If you give it throttle very very slowly the engine speed increases. Any ideas I the timing is on I checked it. all sensors and hoses are hooked up. Right when starting up it idles irractically quick then goes to a smooth idle.. Any help is appreciated thanks in advance
Old Sep 6, 2010 | 05:17 AM
soon2bdropped's Avatar
Default Re: 1998 accprd replacement engine stalling under throttle help!
do you have the tps and map sensor hooked up backwards?
Old Sep 6, 2010 | 07:08 AM
All the plugs are different so i dont believe so. I just pulled the timing belt cover off and timing is dead nuts! Cant figure this out spark plugs are black also!
Old Sep 6, 2010 | 07:09 AM
If a sensor was hooked up wrong wouldnt it throw a CEL? I have no check engine light
NvMySi1183
Mar 3, 2019 05:57 AM
nkhd
Apr 3, 2009 07:23 PM
superfast666
May 29, 2008 08:46 PM
B18C-Hatch
Jul 30, 2007 11:00 PM
