2004 honda accord ex thermostat problem
I drove my accord in highway (50 mile/hr) and the a/c was on, but the water temp seems too high, the needle was on the 3/4 but not the midline, but after i drove for a while, the temp dropped back to normal. this repeated several times. is the thermostat problem or the water pump? thank you
Re: 2004 honda accord ex thermostat problem
When you say the temp was 3/4 but not the middle do you mean the needle was on the left side of the midpoint? How many miles do you have? Is it a v6?
Did you have your coolant flushed yet? If not, that's the first order of business. If the problem persists, replcace your thermastat. Is all your other routine maintanance Oil & filter) done on schedule and up to date?
Just as HondaDen said, a coolant flush. I believe you should get your coolant flushed every 50K miles. Make sure your fan relays are working, coolant flush, check fans and condenser. good luck.
the two fan are acutaly working. no matter my car is in local or highway, whenver i turn on the a/c my car gets overheat
i just flush the coolant and replace the thermostart, but the problem is stil there. when the tempe goes up i mean the needle at "H", the engine has a higher rpm, then i heard a "click" sound from the hood, and then the tempe dropes back to the normal, just wonder is it something wrong with ECT sensor or other senosr?
thank you
thank you
I had that happen to my 05 accord but threw a cel for ect sensor 2. one located on lower right of the radiator. i cleared the code and next day it came back on.. temperature was rising to the H. I had a customer car.. 06 acura tsx.. same engine.. never throw a code.. but using HDS(Honda scantool) found the ect sensor fluctating. while observing it saw that the temperature hit -40f a few time.. replaced the sensor. it fix the vehicle.. however make sure you dont have green corrosion on the connector. if so replace the sub connector, that will also cause a faulty reading.
