1994 Honda Accord passenger side corner lamp turn signal stays on???
As I mentioned in the title, the pass side corner lamp turn signal has been staying on when the car's lights are turned off, and the vehicle's ignition is off.
I installed a set of HID low beams and it seemed to have happened after they were installed but are working properly.
just the corner lamp on the passenger side is staying on, the driverside actually blew the bulb?
at the moment I've removed both bulbs to ensure the battery doesn't drain...and when I replace the driverside with a new good bulb it doesn't even light up when the parking lights are on??
Thanks, eventually I'll have to look at the wiring, but for now at least the front signals in the bumper work properly
Re: 1994 Honda Accord passenger side corner lamp turn signal stays on???
Were you able to figure out the issue? Installed a set of low beam HIDs too and one night, the parking lamp on the passenger side just turned on with the car off and lights off. Trying to figure out what caused this. I did not use a relay kit on it, not sure if it makes a difference.
Don't know if anyone is still wondering about this, but I recently purchased a 94 Accord EX and just had this problem pop up this morning.
Only my passenger corner light was getting constant power with everything turned off, ignition, lights etc. I also have installed HID's in the low beams, but figured these had nothing to do with it as I've had them in for a few weeks with zero problems.
After troubleshooting it for a little while and using info that others have suggested such as a bad ground, frayed wiring, turn signal switch assembly, water in a harness plug above the fuse box under the dash and nothing worked. I started checking all of my fuses and as soon as I pulled the 'interior light' fuse, the light went out. I put the fuse back in, and the light stayed off. I don't know what I did besides pulling the 'interior light' fuse, but it's back to normal and all is working properly.
Just my $0.02....
Just my $0.02....
Yeah, I have had the same thing for about a year or so. When it happens I pull that 7.5 amp fuse and it goes away. Sometimes it comes back. I figured it had something to do with the aftermarket security system I had installed. Maybe not?
I installed SMD lights in my car, and now my dome light stays on haha.
Is it on at full brightness?
i know im mad late but try replacing the integrated control unit i did and it fixed my lights
