1994 Accord Multiple Cooling Issues
Old 08-03-2011, 09:56 AM
  #26
T Wgproductions's Avatar
Default Re: 1994 Accord Multiple Cooling Issues
Originally Posted by holmesnmanny
Are you saying the needle isn't moving at all ? If your system is working good and it's cold out and you're not driving it, there is a chance that the fans might not need to come on until driven, or atleast idled for a longer duration.
The needle moves just never gets to half and the fan never comes on.. I drove the car for about 20 mins highway action.. fan never kicked on...
Old 08-03-2011, 10:02 AM
  #27
astmd1655's Avatar
Well if it's not getting to halfway it probably won't come on. Mine only engaged at 1/2 and above. Are you overheating?
Old 08-03-2011, 06:52 PM
  #28
Today I ran around with it jumped.. never overheated... Tomm will be the test.. I will be letting you know what happens..
Old 08-05-2011, 03:48 PM
  #29
poorman212's Avatar
Joining late.....astmd1655 has you going.
Driving on the highway, you have enough air moving they prob won't come on. Crank it up in the driveway, let it run while keeping an eye on the gauge...might hold the rpms at 2~2.5K for a few minutes to speed this up, even still it may take 15 minutes or so before the car will get warm enough for them to come on.
For the ac relay, you can test the inputs....using a 94 here, if yours is differnt then the wire color maybe off..
WHT - 12 v -fused from under hood
BLK/YEL - 12 v from fan control
RED/BLU - Ground when ac is switched on - I think this comes from the ECU...sorry don't want to get out the books.
Oh, then if all of this is correct, 12 v should go to the compressor -RED wire.
Old 08-11-2011, 08:18 PM
  #30
astmd1655's Avatar
Get it fixed?
clean_sol93
12-11-2011 08:39 AM
Corksil
12-09-2009 06:56 PM
dan200
03-22-2008 07:28 PM
dudeomega2000
01-06-2008 09:51 PM
Doh!
07-03-2006 09:29 PM
Quick Reply: 1994 Accord Multiple Cooling Issues
