1990 Accord LX mt stalls while driving
Old 09-02-2014, 10:15 PM
JAmmons03's Avatar
Default 1990 Accord LX mt stalls while driving
I have a 1990 Accord 4dr LX that has now started to stall while driving. It will start back up immediately after. It seems to happen while driving in city and not in long highway drives. Any clue? I do have check engine code for tps but had that code for a month and this just happened today. Any help would be appreciated.
Old 09-02-2014, 10:28 PM
holmesnmanny's Avatar
Default Re: 1990 Accord LX mt stalls while driving
It's possible that the tps being bad could cause the car to stall but it's not usually the case. Since you know the tps is bad it would be best to fix that and see it clears up the stalling issue. There is a thread in the faq's for how to replace and how to calibrate the tps.
You will need to remove the throttle body and slice a line in each of the rivets so you can back the screws off with a flat head screwdriver to remove the tps. Again, make sure to calibrate the new tps. You could always just pull another throttle body from the junkyard as well. You will need a new throttle body gasket either way.
Old 10-21-2014, 02:55 PM
kidwagon's Avatar
Your ignition switch could be bad. Mine kept cutting off when driving for a week before I figured out my switch was bad. Could wiggle the key and get it to cut off.
metzb1
07-21-2016 07:43 AM
god'schild
05-02-2013 05:18 AM
Shane_1983
11
05-21-2010 11:29 AM
TonyRomo
12-27-2008 03:13 PM
hon2984
01-17-2008 08:57 PM
Quick Reply: 1990 Accord LX mt stalls while driving
