01 Accord No Dash Lights/Tail lights
Old 09-01-2010, 06:03 PM
RedRumLoki's Avatar
Default 01 Accord No Dash Lights/Tail lights
So I just got a 01 Accord EX... I went to install an aftermarket cd player into the car.... I used a harness to do this... and I hooked up the orange illumination wire which I have been told is a big no no... Now I have no dash lights or tail lights... I tested all my fuses and all appear to be in good working order.. I have done hours of research on the internet and discovered 2 things... 1 being that the driver's side multiplexer unit may have been fried so I got one from a junk yard but that changed nothing but made my headlights not work either (I didn't get an EX multiplexer so I got that fixed)... 2 Ive heard that it frys the dimmer switch but you can jump two wires to bypass that and have constant on bright dash lights... My problem is I can't for the life of me figure out which two wires to jump...Any help would be greatly appreciated... Thanks
Old 09-01-2010, 06:32 PM
HonBeer's Avatar
Default Re: 01 Accord No Dash Lights/Tail lights
If you were told it was a "no no". Why did you do the dumb thing by hooking it up? Stupid is as stupid does I guess.
Old 09-01-2010, 07:35 PM
scottypippen147's Avatar
its just a fuse believe me i just blew one the other night on a civic doing that. check the one again that says tail/dash.
Old 09-01-2010, 07:44 PM
bkindness's Avatar
be sure to check the exact one first
Old 09-01-2010, 07:56 PM
RedRumLoki's Avatar
I was only told it was a no no after it had already been done.
Old 09-01-2010, 07:59 PM
RedRumLoki's Avatar
Ok what fuse do I check... The ones under the hood are all good and all the ones in the drivers door jam are all good too??
Old 09-01-2010, 10:16 PM
bseriescrxsi's Avatar
small light fuse under the hood its a 7.5 amp
Old 09-01-2010, 10:33 PM
RedRumLoki's Avatar
Muse panel under the hood says nothing about a small lights fuse... But I checked all the fuses and they were all good... I will triple check them in the daylight tomorrow to make sure again... anyone else got any ideas if its not the fuse...
Old 09-02-2010, 08:00 AM
it is a small lights fuse it should be under the hood but may be under the dash
Old 09-02-2010, 08:40 AM
RedRumLoki's Avatar
Finally found it... 10 amp fuse in the passenger side door jam fuse box.... thanks for the help guys...
Old 11-08-2015, 12:23 PM
lukepch7's Avatar
hi I recently knocked out my dash and rear lights and was thinking I need a new multiplex unit.. which 10a fuse was it that was causing you the issue?
stuck in the dark and dont like the federation
luke p
Old 09-28-2017, 09:51 PM
honda.girl.1991's Avatar
Icon5 Re: 01 Accord No Dash Lights/Tail lights
So by you not buy one for the EX is y it didn't work?
bearstitch
04-24-2016 07:05 PM
tlbounds
03-07-2016 05:56 PM
bennett239
12-14-2015 08:04 PM
fleastang
05-26-2006 03:38 PM
Quick Reply: 01 Accord No Dash Lights/Tail lights
