EEWAGON squad thread
Old May 27, 2009 | 10:17 AM
  #3826
eg831's Avatar
Default Re: EEWAGON squad thread
Ya the rt is multiport and thats what i neeeeedz haha but aight thanks man. I'm takin ur word for this, so if ur wrong ur payin my bills hahaha
Old May 27, 2009 | 10:25 AM
  #3827
HxCforever's Avatar
honestly i dont see why it would be different as long as it's mpfi. all the 4wd stuff is engaged via trans & vicious coupler. ac & power steering have there own harness just like the others. engine wise everything is identical
Old May 27, 2009 | 12:24 PM
  #3828
billboard's Avatar
Originally Posted by eg831
Ok so i REALLY need some help ASAP! I need a new firewall and engine harness. My questions are, would any EF Harness work on our wagons, and also would an RT4WD firewall and engine wiring harness work on my 2WD? PLZ! ASAP!
what happeded to your fire wall???
Old May 27, 2009 | 12:25 PM
  #3829
bamwagon's Avatar
Originally Posted by hondacivicwagon.com
Believe me bambam, unless you're using some sort of super duty glue, you're rails will not be safe supporting any load. Whether you're attaching kia aerostar or EDM roof rails to a wagon, the proper way to install them is by bolting the rails down.
The application you mentioned that hooks around and under the edge of the door jam, and just inside of the weather stripping; is another perfect way to mount load bars to a civic wagon.
Oh, mine are definitely bolted down, I was just pointing out that the Yak or Thule setup is, as you say, plenty strong. It's also far less labor intensive and far more expensive fwiw.
Old May 27, 2009 | 12:33 PM
  #3830
bamwagon's Avatar
I think he means firewall harness, though I'm confused as to which he needs.
Dom, NO, you can't just use a stock mpfi engine harness in a dpfi car. Won't work. Now, if you're talking about changing the whole dash harness, too, then maaaaybe. But why?
Old May 27, 2009 | 03:39 PM
  #3831
prboy1969's Avatar
The one in the enine bayis the same as a year specific 88-89 , 90-91 Hatch or CRX as far asI know. Used one off a 90 Hatch for a Rex a while back . Before I put it in I compared it with a Wagon one I had laying around , the same deal as far as plugs and connectors . Hope that helps , if I get a chance I'll check the manuals (Wagon & Hatch ) .
Old May 27, 2009 | 06:13 PM
  #3832
eg831's Avatar
haha i'm not that dumb.I dont have a single wire in my whole car right now and the harness is not gonna be used on the stock single cam. It's for my b series swap. My stock harness was burnt since i first got the car, so instead of gettin another dpfi harness and having to splice that stuff for the MPFI B series, i'm replacing the stock firewall and engine harness for the RT4wd one which is DPFI. I know that the stock MPFI injectors from the RT harness will not fit, so i'm just splicing those with my b series ones. I was just wondering if any connectors or wiring would be a problem. But thanks for the help man.
Old May 27, 2009 | 06:14 PM
  #3833
eg831's Avatar
ya i meant firewall WIRING HARNESS haha My firewalls doin quite well though, thanks for askin :] haha
Old May 27, 2009 | 06:15 PM
  #3834
eg831's Avatar
Awesome, thanks for the help man.
Old May 27, 2009 | 06:19 PM
  #3835
LoSt is BlaCk's Avatar
i might have an oem roof rack for sale... i think my thule is going to stay on forever... plus the thule can support more weight... guess I'll wait for the right offer...
Old May 27, 2009 | 06:28 PM
  #3836
bamwagon's Avatar
Old May 27, 2009 | 06:44 PM
  #3837
prboy1969's Avatar
"B" series huh , 16 or 18 ?
Old May 27, 2009 | 06:58 PM
  #3838
~sp33~'s Avatar
EFB055
oooo B series RT swap.
Hope he knows what he's up for.
Old May 27, 2009 | 07:17 PM
  #3839
eg831's Avatar
haha NOOOOOO. its not for an rt! It for a WAGOVAN w/ a b series swap. the wiring harness is from an rt cuz rt's are MPFI just like the b series. So if i use the mpfi which comes on rt's and not the 2wd wags i wont have to do much of any splicing.
Old May 27, 2009 | 07:20 PM
  #3840
eg831's Avatar
well i have a b16 in my garage i can finish buildin, but i'm workin out somethin with a b18c5 right now :D
Old May 27, 2009 | 07:34 PM
  #3841
HxCforever's Avatar
just for knock sensor, vtec oil pressure & vtec sylinoid.
Old May 27, 2009 | 07:37 PM
  #3842
eg831's Avatar
[QUOTE=HxCforever;38690601]just for knock sensor, vtec oil pressure & vtec sylinoid.
and the injector clips i believe cuz they're different haha but yes exaaaaactly :]
Old May 28, 2009 | 08:06 AM
  #3843
e12ikktos's Avatar
i have a problem with my b20vtec
my dizzy poped out and the two little horns bent
so what my friend did was change it out and i was able to bring the car back
i drove it but it would take forever to bulid up speed
he said it might be my cap and rotor so i did a tune where i bought spark plug annd spark plug wires
tried to turn on the car then a misfire caused my muffler box to completely explode
any possibilities?
friend says its the dizzy.
Old May 28, 2009 | 09:08 AM
  #3844
honDA_b18's Avatar
^^ did you end up changing the cap and rotor?? or just spark plugs n ****...?
if not try the cap n rotor or a whole new dizzy...
ive had that problem and it once was that the screw on the rotor was ****in loose... lol
Old May 28, 2009 | 10:27 AM
  #3845
HxCforever's Avatar
[QUOTE=eg831;38690631]
i used the ones from the jdm harness as well.
any possibilities?
ya sounds like the dizzy malfunctioned & there was a gas buildup.
Old May 28, 2009 | 01:00 PM
  #3846
My_EFsedan's Avatar
erik bought new cap, rotor, spark plug, and wires..my cousins and i was just standing at my garage and BOOM, sounds like a C4 bomb and **** cause it shook my neighborhood and house..his box muffler completely tore apart. i will try to get a friend to come over so i can use his dizzy to troubleshoot this problem.
Old May 28, 2009 | 01:22 PM
  #3847
HxCforever's Avatar
thats some crazy ****. almost looks like something was blocking the flow & it exploded. has erik ran it since the muffler blew? something clogged in there will give it less back pressure & loss of power.
Old May 28, 2009 | 01:32 PM
  #3848
My_EFsedan's Avatar
no it happened yesterday and the car is here at my house..its weird cause thats a new muffler, can figure out why that **** detonated
Old May 28, 2009 | 01:43 PM
  #3849
HxCforever's Avatar
how was it idling before the muffler blew? any missfires or heitations? any codes? over heating?
Old May 28, 2009 | 03:32 PM
  #3850
e12ikktos's Avatar
idle was high like 1500 cause the dizzy was advanced. moved it and idle was at 900
it would go up and down from 900 to 1000
when i crack vtec thats when it idles at 1500
