del Sol thread v 2.0!
i dont have a white sol with purple wheels, thats kaboom who is leaving florida and going to cali. i have a 96 white del sol with gold wheels
bored + photoshop knock off = del sol type r cluster! aw yea
to ricey?
also picked up an eg ex lip and a P06 5spd ecu for $30 bucks at a junkyard today
to ricey?
lower fogs with boots on ebay for 360 shipped!
http://cgi.ebay.com/ebaymotors/ws/eB...m=250782930943
Well since the Evo is away getting some work done to it because some ******* key the driveside back door
i was able to take out the dely a lil bit and now its resting in my garage heres just a pic of her in the garage
tsup guys.
i think im gonna buy a del sol
i wanna know about these first.
that years are OBD1 and OBD2
and what are the main diferences
body wise between the the older and newest del sol's
also what are
standard
si
and vtec
models?
also do all del sol's tops come off?
any response is appreciated.
also what are
standard
si
and vtec
models?
93-95 are obd1
96-97 are obd2
93-95 has aux. lights
96-97 does not (often referred to as dolphin front)
S is the base model with a d15 1.5 sohc non-vtec
SI is the middle of the road model with the d16 1.6 sohc vtec engine
VTEC is 94+ top end models with the b16 1.6 dohc vtec
all sol tops come off regardless of model
96-97 are obd2
93-95 are obd1
96-97 are obd2
96-97 are obd2
so are the OBD1's basically like 92-95 civic hatch's
whats up with the CRX tags?
also are the front end interchangeable? like with the ek's or the egs?
are the ECU's and engine harness the same as the EG's? can i swap a vx complete swap [engine, trans, ecu, axle, harness]into a del sol with no issues?
body wise is there a difference between the s, si and vtec model? or is the engine the only difference?
do all models come with power window, power steering, and A/C?
thanks
what front end is this? i like the fog light slots it has? what model is this from?
That front is a 93-95 del sol. A normal USDM del sol wont come with the lower fog lights in the bottom corners thats a JDM/EDM thing. But you can buy them and install them if you have 400+ dollars.
