del Sol thread v 2.0!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by e gee two »</TD></TR><TR><TD CLASS="quote">del sol's are for ****.
ahahahahahaha
</TD></TR></TABLE>ahahahahahaha
</TD></TR></TABLE>You are one to talk.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by WrongWD »</TD></TR><TR><TD CLASS="quote">damn. so the hatchback just failed emissions.</TD></TR></TABLE>pwned. It would have passed out here
What part did you fail? what motor and such? Inquiring minds want to know
bone stock d15b2......
failed co2 and hco
and i knew you would chime in about emissions. because it failed i cant get it registered immediately, so im tryin to figure out what to do.
failed co2 and hco
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by WrongWD »</TD></TR><TR><TD CLASS="quote">bone stock d15b2......
failed co2 and hco
and i knew you would chime in about emissions. because it failed i cant get it registered immediately, so im tryin to figure out what to do.</TD></TR></TABLE>New Cat, plugs, wires, dizzy cap and rotor, change your oil, and if all else fails research putting some alcohol in your gas tank
EDIT for ownage: what not to do in a del Sol
failed co2 and hco
o2 and cat are relatively new i think, (i havent looked closely)
i havent torn apart the ignition system or done any tests... ive been so ****** busy. i will though, and find out whats goin on.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by WrongWD »</TD></TR><TR><TD CLASS="quote">o2 and cat are relatively new i think, (i havent looked closely)
i havent torn apart the ignition system or done any tests... ive been so ****** busy. i will though, and find out whats goin on.</TD></TR></TABLE>Also, on a motor that old it could be something related to the piston rings or valve seals. If it's burning a lot of oil then it will definately fail. Maybe try a thicker oil for when you do the test, then change it afterward?
For someone who has easy as hell emissions, I seem to be able to find a few ways to get past it
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by memphisraines26 »</TD></TR><TR><TD CLASS="quote">just a light scuff. those 16s?</TD></TR></TABLE>
Wheels are fine, they're just dirty and they're 15's.
Notice there's part of the rotor gone
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by imm0rt41 »</TD></TR><TR><TD CLASS="quote">Also, on a motor that old it could be something related to the piston rings or valve seals. If it's burning a lot of oil then it will definately fail. Maybe try a thicker oil for when you do the test, then change it afterward?
its not burning much oil as far as i can tell, but i think there may be some blow by. talked to a few experts at work and they suggest changing the oil and cleaning out the return system, as the hydrocarbons will have accumulated heavily in the oil and influence emissions DRASTICALLY. We'll see what other suggestions I can gather and take care of.
things are looking a little brighter though, because I didn't want the swap to be the first thing i do to the car
guess thats what i get for trying to smog a car with 278,000 miles on it
</TD></TR></TABLE>its not burning much oil as far as i can tell, but i think there may be some blow by. talked to a few experts at work and they suggest changing the oil and cleaning out the return system, as the hydrocarbons will have accumulated heavily in the oil and influence emissions DRASTICALLY. We'll see what other suggestions I can gather and take care of.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by WrongWD »</TD></TR><TR><TD CLASS="quote">its not burning much oil as far as i can tell, but i think there may be some blow by. talked to a few experts at work and they suggest changing the oil and cleaning out the return system, as the hydrocarbons will have accumulated heavily in the oil and influence emissions DRASTICALLY. We'll see what other suggestions I can gather and take care of.
</TD></TR></TABLE>psh, only 278k? My step-mom sold her 95 civic EX coupe with 380k on it and it still ran like the day it was made. It just goes to show you what routine maintenance can accomplish...
Anywho, i know you can get that car to smog with that motor in it, just might take a bit of work =/
</TD></TR></TABLE>psh, only 278k? My step-mom sold her 95 civic EX coupe with 380k on it and it still ran like the day it was made. It just goes to show you what routine maintenance can accomplish...Anywho, i know you can get that car to smog with that motor in it, just might take a bit of work =/
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by imm0rt41 »</TD></TR><TR><TD CLASS="quote">psh, only 278k? My step-mom sold her 95 civic EX coupe with 380k on it and it still ran like the day it was made. It just goes to show you what routine maintenance can accomplish...
Anywho, i know you can get that car to smog with that motor in it, just might take a bit of work =/</TD></TR></TABLE>
yeah i'm thinkin if i do a major tune up to it we should be able to figure something out. Additionally, it started to overheat.... ******* cars. gotta figure that one out too.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by WrongWD »</TD></TR><TR><TD CLASS="quote">yeah i'm thinkin if i do a major tune up to it we should be able to figure something out. Additionally, it started to overheat.... ******* cars. gotta figure that one out too.</TD></TR></TABLE>Check the thermostat, thermostat housing gasket, all the rubber lines for cracks, and finally the top and bottom of the radiator. Those are the parts on the cooling system that will own you, especially with that kind of mileage.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chads »</TD></TR><TR><TD CLASS="quote">so whats up with the blue racing stripes on the delsol? i thought this was honda-tech not car domain....
</TD></TR></TABLE>She's the original owner, and it is fast as hell for a stock honda so I can't complain. Gotta love being the original owner of a 1996 VTEC
Because it makes it look like its hauling *** even when its sitting still
</TD></TR></TABLE>Because it makes it look like its hauling *** even when its sitting still
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by imm0rt41 »</TD></TR><TR><TD CLASS="quote">Forgot who won, but it doesn't matter because it was funny as hell
dude. was there any question who won the race?
</TD></TR></TABLE>dude. was there any question who won the race?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by WrongWD »</TD></TR><TR><TD CLASS="quote">dude. was there any question who won the race?
</TD></TR></TABLE>There was some questionable usage of foot power at the beginning of the race by both parties. Oh and it looked like Jimmy jumped the gun
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by imm0rt41 »</TD></TR><TR><TD CLASS="quote">There was some questionable usage of foot power at the beginning of the race by both parties. Oh and it looked like Jimmy jumped the gun
and i still schooled the ****
</TD></TR></TABLE>and i still schooled the ****
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by WrongWD »</TD></TR><TR><TD CLASS="quote">and i still schooled the ****
</TD></TR></TABLE>Yeah, but you were no match for my pedal-power!
