del Sol thread v 2.0!
Old Nov 29, 2006 | 04:25 PM
  #7076
chads's Avatar
Default Re: (Slo-EG1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Slo-EG1 &raquo;</TD></TR><TR><TD CLASS="quote">
damn that was fast
i have a bunch of other stuff an the way too buts its all oem goodies WOOT
Old Nov 29, 2006 | 04:27 PM
  #7077
chads's Avatar
Default Re: (hybridpatient95)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hybridpatient95 &raquo;</TD></TR><TR><TD CLASS="quote">this is the only picture i have right now. im still not finished lol
still missing 3in exhaust, fuel pump, chipping my ecu, and headstuds
setup is
b16 lsd tranny
sc34 turbo
wow
Old Nov 29, 2006 | 04:28 PM
  #7078
JDM-Punk's Avatar
setup is
b16 lsd tranny
sc34 turbo
looks nice... def love seeing some bullhorns
Old Nov 29, 2006 | 05:01 PM
  #7079
Berman's Avatar
Hey family Good news, after xmas I will be spending money on suspension and wheels all going to plan, bout time huh?
Turbo sol looks mean! that's a nasty fridge! ...see why you cant fit the aux lights!
Old Nov 29, 2006 | 05:56 PM
  #7080
memphisraines26's Avatar
ok i put a new slave cylinder and omnipower clutch cylinder int the car tonight. I bled the system by the old man pumping 5 times, holding, and i open the bleeder valve to shut off. but the pedal isn't all the way back up. any ideas fam?
Old Nov 29, 2006 | 06:01 PM
  #7081
ianae86's Avatar
Default Re: (memphisraines26)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by memphisraines26 &raquo;</TD></TR><TR><TD CLASS="quote">ok i put a new slave cylinder and omnipower clutch cylinder int the car tonight. I bled the system by the old man pumping 5 times, holding, and i open the bleeder valve to shut off. but the pedal isn't all the way back up. any ideas fam?</TD></TR></TABLE>
Check the master cylinder piston that goes to your pedal. You may not adjusted the nut right. You mean the pedal won't get off the floor or its got pressure and is just sitting low?
Old Nov 29, 2006 | 06:09 PM
  #7082
ATS*EG2's Avatar
its not the same as the brake system. so heres how to bleed the clutch......
open bleeder,push pedal to floor. close bleeder, lift pedal up repeat like 15 times.
its easier with 2 people
Old Nov 29, 2006 | 06:12 PM
  #7083
ianae86's Avatar
Default Re: (ATS*EG2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ATS*EG2 &raquo;</TD></TR><TR><TD CLASS="quote">its not the same as the brake system. so heres how to bleed the clutch......
its easier with 2 people </TD></TR></TABLE>
I've used the pump and release method many times (get your mind out of the gutter ) and its worked for me. But to each their own. There seem to be a lot of techniques.
Old Nov 29, 2006 | 06:17 PM
  #7084
ATS*EG2's Avatar
Default Re: (ianae86)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ianae86 &raquo;</TD></TR><TR><TD CLASS="quote">
I've used the pump and release method many times (get your mind out of the gutter ) and its worked for me. But to each their own. There seem to be a lot of techniques.</TD></TR></TABLE>
but hes got no pressure right because he is replacing the clutch master, so if you pump the pedal goes to the floor. ahh oh well this guy aint even on right now haha
hell figure it out
Old Nov 29, 2006 | 06:23 PM
  #7085
TeamHin's Avatar
solllllllllllllllllllllll
Old Nov 29, 2006 | 06:25 PM
  #7086
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ianae86 &raquo;</TD></TR><TR><TD CLASS="quote">Check the master cylinder piston that goes to your pedal. You may not adjusted the nut right. You mean the pedal won't get off the floor or its got pressure and is just sitting low?</TD></TR></TABLE>
thats exactly how it is. i know with the omnipower it's supposed to have a shorter push but it I can pull the pedal towards me like an inch.
ray what is your method?
didnt get a chance to put these on tonight
Old Nov 29, 2006 | 06:27 PM
  #7087
ATS*EG2's Avatar
thats if theres still air in your clutch lines.
Old Nov 29, 2006 | 06:30 PM
  #7088
hmm i'll have to try that this weekend. i'll need that 2nd person for sure and some tubing for the bleeder. it does cut down on shifting.
and ian i did adjust that nut but the pedal isnt at the same height as the brake pedal but i do have pressure. oh and no more problems shifting into 2nd and 5th. the old master was nissin oem with grease oozing out.
Old Nov 29, 2006 | 06:37 PM
  #7089
solerizr's Avatar
Yeah i like those 1 man bleeder kits: theyre only like $5 at autozone.
Old Nov 29, 2006 | 06:47 PM
  #7090
how do those work? just place on bleeder valve, open it up, and just pump?
Old Nov 29, 2006 | 07:04 PM
  #7091
also what is the deal with "wantabe" wheels/
Old Nov 29, 2006 | 07:07 PM
  #7092
hybridpatient95's Avatar
thanks guys.. yea now you know what i mean about the foglights. lol ima try to get some more pics up soon.. i need some suspension asap lol
Old Nov 29, 2006 | 07:14 PM
  #7093
as soon as i can get them off i'll be selling my kyb agx shocks and cheap coilover sleeves!
Old Nov 29, 2006 | 07:25 PM
  #7094
RARE_EG2's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by memphisraines26 &raquo;</TD></TR><TR><TD CLASS="quote">also what is the deal with "wantabe" wheels/</TD></TR></TABLE>
what do you mean? knockoffs?
Old Nov 29, 2006 | 08:17 PM
  #7095
INCNTRL4's Avatar
if ur giving them away, ill take a set, lol
Old Nov 29, 2006 | 08:19 PM
  #7096
RARE_EG2's Avatar
Default Re: (INCNTRL4)
same here
Old Nov 29, 2006 | 08:23 PM
  #7097
INCNTRL4's Avatar
Default Re: (RARE_EG2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RARE_EG2 &raquo;</TD></TR><TR><TD CLASS="quote">same here </TD></TR></TABLE>
go pick me up a set from him, and ship me a pair
Old Nov 29, 2006 | 08:25 PM
  #7098
RARE_EG2's Avatar
hes in norcal lol
Old Nov 29, 2006 | 08:28 PM
  #7099
INCNTRL4's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RARE_EG2 &raquo;</TD></TR><TR><TD CLASS="quote">hes in norcal lol</TD></TR></TABLE>
I don't give a expletive, dont get cheeky with me bitch
Drive your car TOPLESS for once, and go pick them up
Old Nov 29, 2006 | 08:32 PM
  #7100
RARE_EG2's Avatar
hahaha hes about a good 5hrs away..easy lol..and no driving topless for me
