DA Integra's Only
Looks great! Main reason I've kept mine for 20 + years..
Got the motor in and most stuff bolted up, was waiting on parts to be coated and looks like those are done!
Car is running, had to make some water lines and all since this turbo is water cooled.
My buddy made me a front TQ mount too. Waiting to line up dyno time with the tuner
Well after my last debacle, taking a break from the car, and then getting it back together, dyno session went super smoothly and I'm not driving this thing around and enjoying it finally.
Basically TLDR, I had this sleeved block for a long time, got it together and had issues, ended up being these morons didn't press the sleeves in all the way, and Cyl 1 & 2 were blowing compression into the cooling system under boost, got a competent machine shop to fix it all up and here we are.
That blue teg is so clean. all put together with that sfr intercooler. you got pics of the interior? Also, i'm pretty new to this but I got a question (if you know) do you know the spline count and width of the da9 teg's steering wheel column shaft? I can't find any solid accurate info.
