Forced Induction Everything Forced Induction (Ex: Turbo Kits, Intercoolers, Blowoff valves, IC Piping, Turbo Manifolds)
MOROSO OIL PANS - from $129 FREE SHIPPING !! Perfect for Turbo Applications !
Old Oct 2, 2014 | 11:16 AM
  #1201
lightning's Avatar
Default Re: MOROSO OIL PANS - from $129 FREE SHIPPING !! Perfect for Turbo Applications !
All PMs replied, thanks again !!
Old Oct 11, 2014 | 05:51 PM
  #1202
ProjectJDM's Avatar
whats the difference between this and the more expensive one?
Old Jan 12, 2015 | 08:54 PM
  #1203
lightning's Avatar
Old Jan 12, 2015 | 08:55 PM
  #1204
lightning's Avatar
▼▼MOROSO #20911 Steel Wet Sump Oil Pan for B-SERIES:
CHECK PRICE or ORDER 20911 NOW
Fits Acura 1.8L VTEC/Non-VTEC Engine, and has a Stock Configuration Sump and STOCK Capacity. Fits: 1994-01 Acura Integra incl. Type-R with 1.8L VTEC and Non-VTEC engines. Also fits Acura and Honda B16A, B16B, B17A, B18A, B18B, B20A, and B20Z.
Uses Stock Oil Pump and Pickup.
Works with OEM exhaust manifold and most aftermarket exhaust/header combinations.
Includes a sump baffle that fully surrounds oil pump pickup for increased oil control while accelerating, cornering and braking. Features a Turbo/Supercharger oil drainback fitting as well as a magnetic drainplug and temperature sensor fitting already welded to the pan; no more hassle trying to find a competent welder ! It is also clear zinc plated for durability and corrosion resistance.
Front of Pan - Oil Return - 1/2"NPT
Rear of Pan - Oil Temp Sending Unit - 1/2"NPT and drain plug
INSTALLATION NOTE for OIL PANS:
1)When installing plugs, sealant MUST be used, either tape or paste.
2)When installing gaket, sealant must NOT be used. It is installed DRY. Please make sure it is clean and dry. Best option is to replace gasket and use an OE gasket no cheapie ones!
99% of leaks are a result of not following these procedures.
▼▼MOROSO #20912 Custom Aluminum H22 Wet Sump Oil Pan 5.5qt.
CHECK PRICE or ORDER 20912 NOW
Fits H22 Engines. Features a Turbo/Supercharger oil drainback fitting as well as a magnetic drainplug and temperature sensor fitting already welded to the pan; no more hassle trying to find a competent welder !
▼▼MOROSO #20830 Custom Steel D-Series Wet Sump Oil Pan OE Capacity. - TEMPORARILY BACKORDERED !!! 1/2012
CHECK PRICE or ORDER 20830 NOW
For 1988-95 D-Series Engines and 1986-89 Integra. Features a Turbo/Supercharger oil drainback fitting as well as a magnetic drainplug and temperature sensor fitting already welded to the pan; no more hassle trying to find a competent welder ! Uses stock pickup. Available EXCLUSIVELY from Lightning Motorsports !
▼▼MOROSO #20908 Custom Aluminum D-Series Wet Sump Oil Pan 5.5qt.
CHECK PRICE or ORDER 20908 NOW
For 1988-95 D-Series Engines and 1986-89 Integra. Features a Turbo/Supercharger oil drainback fitting as well as a magnetic drainplug and temperature sensor fitting already welded to the pan; no more hassle trying to find a competent welder ! Please note requires a seperate oil pickup.
▼▼MOROSO #20910 B-Series Road Race
CHECK PRICE or ORDER 20910 NOW
▼▼MOROSO #20915 K-Series
CHECK PRICE or ORDER 20915 NOW
Please call 1-225-752-2738 for International or Non-Continental orders, or for orders that may need to be Expedited.
Please Call or PM if you have any other questions or are interested in any of the other pans Moroso has to offer.
Old Jun 6, 2015 | 06:35 AM
  #1205
oneludesol's Avatar
GDD's Dr. Phil?
Community Builder
What's the promo code for price and free shipping?
Old Jul 17, 2015 | 06:26 AM
  #1206
Slurm's Avatar
Wimmy Wam Wam I sent you a PM
Old Aug 25, 2015 | 06:40 PM
  #1207
lightning's Avatar
All PMs replied, thanks for the orders !!
Old Aug 31, 2015 | 05:57 PM
  #1208
lightning's Avatar
We appreciate the HT business, thanks again !
Old Sep 3, 2015 | 10:54 AM
  #1209
lightning's Avatar
Old Sep 5, 2015 | 07:38 PM
  #1210
Slurm's Avatar
Wimmy Wam Wam I never got a pm
Old Sep 5, 2015 | 08:28 PM
  #1211
lightning's Avatar
Please reshoot, not seeing on our end, thanks !
Old Sep 8, 2015 | 09:51 PM
  #1212
lightning's Avatar
Old Sep 13, 2015 | 12:38 AM
  #1213
deephouselounge's Avatar
Price on the site is higher
Old Jan 5, 2016 | 07:36 PM
  #1214
lightning's Avatar
Old Jan 14, 2016 | 01:33 PM
  #1215
lightning's Avatar
Old Jan 21, 2016 | 08:49 PM
  #1216
lightning's Avatar
Old Apr 10, 2016 | 11:03 AM
  #1217
lightning's Avatar
Old Sep 3, 2016 | 08:46 PM
  #1218
VicBernal68's Avatar
Hi, I'm looking at buying an oil pan MOROSO #20911 in a couple of weeks, how would I go about paying for it? And I need it shipped to New York. Thanks in advance!
Old Dec 12, 2016 | 07:31 PM
  #1219
lightning's Avatar
Thanks for the orders, please PM for questions !
Old Dec 21, 2016 | 04:34 PM
  #1220
Maelong's Avatar
PM'd a few days ago but havent got a response. Assuming its busy due to the holiday season?
Old Mar 3, 2017 | 11:05 PM
  #1221
TheSeaIsSilent's Avatar
how much would it cost for B16A2 oilpan? 95903 shipping zip
Old Jul 17, 2017 | 04:09 PM
  #1222
lightning's Avatar
Old Sep 11, 2017 | 01:29 PM
  #1223
lightning's Avatar
Old Oct 16, 2017 | 07:04 PM
  #1224
lsierra's Avatar
Hello seller I have a few items you guys have on eBay I'm interested in buying but also wanted to purchase this oil pan. Is there any special pricing for buying multiple items from you
zerovandez
Feb 12, 2014 06:26 PM
93grayeg
Jan 4, 2013 10:45 AM
Will_H
Nov 20, 2007 09:35 PM
integrasi
Aug 20, 2004 08:45 AM
miataguy
18
Aug 24, 2003 04:49 PM
