Forced Induction Everything Forced Induction (Ex: Turbo Kits, Intercoolers, Blowoff valves, IC Piping, Turbo Manifolds)
The G.E. Experience
Old Sep 22, 2011 | 03:17 PM
Golden Eagle's Avatar
Default The G.E. Experience
The G.E. Experience
Customers often ask if they need to send in a core for exchange. We do not like to do exchanges. It’s preferred for you to send in a core.
We sell what are called “cores” for you to work with. Each core gets inspected for any damage or any compromised threads, cracks, defects etc.
Although Most customers send in cores to save a few bucks.
Each sleeved engine core block is custom made to fit the desired specs of the customer. First step is to clean the core in the hot tank. After going through the hot tank all G.E. provided cores get bead blasted. If you want your personal core you have sent in bead blasted that will be a small additional fee. The bead blast really brings out the best of the engine as far as cosmetics go. Yes we hot tank the block again after the bead blast in case your wondering. Next the sleeves need to be CNC machined to 0.030 thousandths of an inch less than requested in millimeter bore. After the sleeves are pressed in; we then put the block back on the CNC Mill to have the ''O'' Ring groove cut in (upon request) . Then it's time for the block to have the final bore/hone work. ''Note'' We will request the pistons here for final bore/hone. After that is accomplished. We do a pressure test on the core to make sure the sleeves aren’t compromised during the install process. We double check all work done on the blocks through each process.
If you supply the core we will ask if you want us to check and see if you need a align bore. You will be contacted if align bore is needed. That will be an additional fee. ''Note'' When ever you severely over heat your engine, over tighten the mains, add a Girdle or spin a bearing you will need a align bore, to ensure proper function.
Now the block is given a generous spray bath off ''Cosmoline'' Lubricating - Protecting spray (to prevent rust). The blocks is now ready for shipping or further work, such as a build or main Girdle install. I hope this brief description answers any questions you may have about the G.E. resleeving process. Feel free to give us a Call/Email.
Thank you,
Bob Woodcock
Old Sep 22, 2011 | 03:40 PM
AllShowNoGo727's Avatar
Default Re: The G.E. Experience
badass! GE FTW!
Old Sep 27, 2011 | 03:41 PM
Sleeving
Although there are many different options when choosing a sleeving company for your block, we would like to point out some factors for why you should choose Golden Eagle Mfg. for your engine sleeving needs.
Process - We use precision CNC equipment for sleeve installations; that assures proper tolerances time and time again without any mistakes. We are ISO9002 qualified and MILI45208 certified. No local engine machine shop can even come close to our tolerances!
Reliability - All of our blocks are tested and re-tested to assure the reliability that the customer deserves.
Warranty and Customer Support - We carry the best warranty in the business. Lifetime warranty against sleeve cracking and sinking. We have on hand some of the most educated engine builders in the industry to answer any questions or concerns a customer may have.
Turn Around Time – Our turn around time is second to none. We can usually sleeve and deck your block within 3-4 weeks. If you need it sooner, we offer an express service for an extra fee that gets your block done in 5 days
Experience – We have sleeved more blocks than all other sleeving companies COMBINED. We have a proven track record of reliability and performance.
Golden Eagle Mfg. has more experience sleeving 4 cyl aluminum blocks than all other sleeving companies in the market. We have tested and perfected the sleeving process so there are no mistakes. Golden Eagle Mfg. sleeved blocks carry the best warranty and customer support in the business. Our blocks are guaranteed not to leak, sink or mix oil and water, WE GUARANTEE IT! With our precision CNC equipment and military specification tolerances, no one can compete with the quality and reliability available when you get a Golden Eagle Mfg. sleeved block.
Most of the top racers in the Import Drag Racing circuit rely on Golden Eagle Mfg. sleeved blocks to keep them winning and breaking records. Race teams like Team Bergenholtz, Lisa Kubo, BisiMoto Engineering, Eggum Racing, JJ Olson and many others exclusively use Golden Eagle Mfg. sleeved blocks. These teams have no room for error and that is why they rely on us and our proven reputation for their performance engine block needs.
Re-sleeving available for the following engines
Honda/Acura
D15, D16
B16, B17, B18A/8, B18C
B20
H22, H23
F20, F22, F23
K20, K24
L15 (Honda Fit)
Nissan
SR20
Toyota
2ZZ
Scion
2AZ
Subaru
EJ20, EJ25
Ford/Mazda
DURATEC
Saturn
ECOTECK
Porsche
944
Saturn
1.9
Call for Pricing & Information
909-592-4311 x13
Honda/Acura B16/17/18 B20(CRV) Honda K20 K24 Honda D16 Ford/Mazda Duratec Subaru EJ Series Engines
Old Sep 30, 2011 | 12:59 PM
Old Sep 30, 2011 | 01:13 PM
Old Oct 6, 2011 | 02:31 PM
chippy
Nov 30, 2006 08:46 AM
blackeg
Apr 25, 2006 06:45 AM
JDM978
Apr 8, 2005 11:00 PM
miller
Jan 29, 2004 09:28 AM
TOFU.man
Nov 4, 2003 06:27 AM
