zex kit question
Old Nov 26, 2001 | 08:31 PM
b18c-93's Avatar
New User
Default zex kit question
i just put a zex kit on my integra witha b16a swap, i have intake header and ext with msd and fuel pressure reg i was wondering what shot shold i run or what will be safe a 55 65 or 75 i would really app if some body could answer me.
Old Nov 26, 2001 | 09:14 PM
FrostyGSR's Avatar
New User
Default Re: zex kit question (93gsb16a)
I think i read on zex.com once that if you are using upgraded engine components other than I/H/E you should contact zex for more info on how to run safely. I'm sure they would be able to tell you how much you can run....
Old Nov 27, 2001 | 02:37 AM
Mista Bone's Avatar
D Tranny Guru
65 shot with 75 fuel jet, set timing to 14 BTDC, and fuel pressure at 50-52 psi with vacuum line disconnected.
In order to run the 75 shot you HAVE to have a better fuel pump.
Old Nov 27, 2001 | 09:56 AM
GSRacer's Avatar
New User
Default Re: zex kit question (Mista Bone)
ok, this is a zex kit he's talking about. i ran 75 shot all day long with my kit. all i had was intake, header & exhaust. all you need to get is colder plugs and retard your timing. yes, a better fuel pump would be recomended, but not nesesary.
[Modified by GSRacer, 10:56 AM 11/27/2001]
Old Nov 27, 2001 | 12:01 PM
Mista Bone's Avatar
D Tranny Guru
Default Re: zex kit question (GSRacer)
well if the botttle pressure gets above 1000 psi, stock pump won't keep up. I found this out when I left car in the hot sun waiting for staging lanes to open.
Burnt #2 piston, 15% leakdown, still runs just the same!
knightnam
Jun 27, 2004 09:31 PM
Griff
Jun 14, 2004 07:31 PM
preluder
Apr 14, 2003 01:49 PM
DaNish
Nov 22, 2001 07:21 PM
