zex nitrous
Old Apr 13, 2004 | 05:26 PM
af97civic's Avatar
Default zex nitrous
i have a d16y8 with the basic bolt on's.i also have a obd1 ecu that is chipped.i would like to run nitrous but i heard that is not a good idea to run that with a chipped ecu.but i heard zex is the safest and it has a controller that will fix the a.f. mixture to run the nitrous saftely.i need some more info on this before i lay down the coin to get the kit. thanks
Old Apr 13, 2004 | 05:35 PM
Hoosier Daddy's Avatar
Default Re: zex nitrous (af97civic)
ZEX won't necessarily create a good a/f mixture, but if it detects a bad ratio, it won't spray nitrous. I sprayed a stock B16 with a 75 shot and advanced timing (bad) with no problems. You should be fine with at least a 50 shot. What program is your ECU chipped with?
Old Apr 13, 2004 | 05:41 PM
af97civic's Avatar
Default Re: zex nitrous (Hoosier Daddy)
jun program
-redline9500
-vtec5500
-no speed limiter
0618turbocivic
Jul 25, 2006 08:38 AM
integranator
Dec 22, 2002 02:58 PM
ridnmyhonda
Jan 9, 2002 06:38 AM
EVOCELICA
Aug 31, 2001 06:46 PM
