Z6 Build, Need Advice
Old Oct 27, 2011 | 05:04 PM
nothing_shocking's Avatar
Default Z6 Build, Need Advice
I'm putting together a D16Z6 for next year. So far I have Vitara pistons .5 over, Eagle rods, Supertech valves and valve springs and ACL bearings. I have a big 16g Mitsu turbo (TD05), 450cc blue top Mitsu injectors and a Walbro 255 fuel pump. Also, a Fidanza 7lb flywheel, 2.5 inch down pipe mated to a 3 inch exhaust. Everything not listed is stock (or at least assume stock for this thread). Plan on getting it tuned by Slow Motion Motorsports in Columbus, OH on an S300.
My questions are...
1) What is the absolute max power limit for this set up?
2) Will I be able to reach 300hp (not whp) with this set up and, if so, what PSI will I need to run?
3) Would a block guard be a good investment?
If anyone has any suggestions for what I can improve or anything, feel free.
Old Oct 27, 2011 | 05:16 PM
SovXietday's Avatar
Default Re: Z6 Build, Need Advice
1) You're limited to about 250-275whp safely with those injectors.
2) read 1.
3) Nope. They are a waste of money.
Old Oct 27, 2011 | 05:33 PM
I guess I forgot to add that I want this to be as reliable as possible too.
EFinAwesome
May 22, 2012 06:18 PM
nothing_shocking
13
Nov 8, 2011 07:20 AM
j0keefe21
Jul 5, 2009 07:29 PM
meams
Jun 15, 2003 07:16 AM
