your gauge pod???
Old Feb 21, 2004 | 02:14 PM
KiNG $h!t's Avatar
Default your gauge pod???
did most of u bolt ur gauge pod or did u find another way to makew it stick next to the door??
Old Feb 21, 2004 | 02:34 PM
KiNG $h!t's Avatar
did you guys drill a hole into your pillar for the guage wires or run them somewhere else? I didn't really see how i could run them through the pillar and where they come out at the bottom. Also, did you drill the pod into the pillar or use double sided tape? Thanks for any help!
Old Feb 21, 2004 | 02:43 PM
bluebullet's Avatar
Default Re: (this guy 2fast)
I drilled holes and used the snap in plugs that autometer gives you, wires fit fine.
Old Feb 21, 2004 | 02:53 PM
KiNG $h!t's Avatar
can some of u post pics too thanx
Old Feb 21, 2004 | 03:48 PM
T-RO's Avatar
I drilled 2 small holes in the pod & piller. I then stuck a small bolt with a washer in there and secured it behind the pillar with a small nut. I painted the bolt head and washer black to match the pod.
I also drilled 2 larger holes in the pillar. 1 runs all my wires, and the other (larger) runs my tubing for boost and oil.
Old Feb 21, 2004 | 05:03 PM
NuclearB18B's Avatar
Default Re: (T-RO)
i always hated the way gauges looked on the pillar...so i made my own...
Old Feb 21, 2004 | 05:06 PM
95integraLS's Avatar
Default Re: (ha illuminato un)
i drilled one hole and used the screw thingies...then i tucked the rest into the lining on the pillar.
Old Feb 21, 2004 | 05:42 PM
J.R.'s Avatar
the wires should fit fine
Old Feb 21, 2004 | 08:45 PM
mskibbz-T's Avatar
Default Re: (J.R.)
FYI - For Integras, those pillars are like $15 to replace, so don't stress drilling it... I have my 60mm gauges in a pillar pod but dislike it - gonna probably get some greddy gauge holders to throw on my dash instead.
Old Feb 21, 2004 | 08:58 PM
TRE_'s Avatar
i just drilled 2 screws and tucked the wires...
Old Feb 21, 2004 | 09:00 PM
INVALID's Avatar
From: Why so you can pretend like youre interested, FL/OK
Default Re: your gauge pod??? (this guy 2fast)
How do you justify leeching from another individuals original thread only to go and create a number of similar threads to find an answer that was posted in the original one? We all want answers, but at least be patient about it. Choose the best forum and be done with it. I'm a hypocrite.
https://honda-tech.com/zerothread?id=775108
https://honda-tech.com/zerothread?id=775153
https://honda-tech.com/zerothread?id=775147
https://honda-tech.com/zerothread?id=775123
Run the wires behind the pillar with the OEM wires, then if necessary drill at the bottom where the hole isn't even viewable. Don't you think you're making this a little too difficult than it is?
ha illuminato un very original install. I have never seen it before, what is that you have surrounding the gauges? Secure enough for daily bumps and potholes?
Old Feb 21, 2004 | 09:27 PM
IN VTEC's Avatar
I used four black trim screws from the hardware store. I usually keep several of them laying around in the spare hardware box.
Old Feb 22, 2004 | 06:24 AM
E Swift's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ha illuminato un &raquo;</TD></TR><TR><TD CLASS="quote">i always hated the way gauges looked on the pillar...so i made my own...
Damn! How did you do that?
Old Feb 22, 2004 | 07:46 AM
rezo's Avatar
at first i tried using double sided tape cept it would fall off all the time (right when i would be hitting a corner hard or doing something fun lol)
anyways i fixed it by running a screw just above the top most gauge, then painting the top of the screw black w/ spraypaint on a q-tip (spray some paint in the cap, then dip a q-tip in it and dab it on the screw)... you cant even see it unless you know its there.
heres a pic:
mine is the autometer kind so it pretty much fits in place (the bottom), so it only needed a screw to hold the top part up
as for the wiring, i ran it down through the dash, down to where the pedals are, behind the stereo head unit, and to the control unit which i mounted on the passenger side of the center console.
this is what it looks like:
anyways it works out nicely so you cant see any wires (unless you lay down on the passenger-side floormat.. lol)
Modified by rezo at 4:57 PM 2/22/2004
Old Feb 22, 2004 | 07:53 AM
Jdm93civic's Avatar
Default Re: your gauge pod??? (rezo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rezo &raquo;</TD></TR><TR><TD CLASS="quote">at first i tried using double sided tape cept it would fall off all the time (right when i would be hitting a corner hard or doing something fun lol)
heres a pic:
yes my fren u have some phat *** gauges.....
Old Feb 22, 2004 | 07:57 AM
rezo's Avatar
Default Re: your gauge pod??? (Jdm93civic)
yeah you should see them at night &gt;:D
Old Feb 22, 2004 | 08:19 AM
Jdm93civic's Avatar
lol take a pic for me please at night i want to see!!!!
Old Feb 22, 2004 | 09:27 AM
Blackack26's Avatar
Default Re: (Jdm93civic)
I drilled 4 holes and used the little plastic barbed things to hold it on.....I couldn't tuck the wires because the boost gauge is mechanical. So I drilled a couple of large holes in the a-pillar
Old Feb 25, 2004 | 06:30 PM
rezo's Avatar
Default night gauges
just for you:
you really have to see them to realize their true awesomeness the glow they give off is awesome.
Old Feb 25, 2004 | 06:33 PM
FlaN.'s Avatar
defi gauges
Old Feb 25, 2004 | 08:57 PM
Jdm93civic's Avatar
Default Re: night gauges (rezo)
omg DUDE.....im surprised those are white by now........i would have busted all over them junks......lol j/k
Old Feb 26, 2004 | 05:19 AM
B17aTrbo's Avatar
New User
Nice gauges! I couldn't use them in va cause they'd get stolen
Old Feb 26, 2004 | 05:32 AM
MiraiZ's Avatar
Default Re: night gauges (B17aTrbo)
Old Feb 26, 2004 | 07:22 AM
Dracord's Avatar
Mine were screwed into the stock a pillar, then molded on so i just replaced my a pillar
Old Feb 26, 2004 | 07:23 AM
BoostedSi's Avatar
Default Re: (Dracord)
I just screwed mine in
