yea nitrous not working good
Old Dec 21, 2008 | 10:56 PM
bossm's Avatar
Default yea nitrous not working good
yea well i am running 75 shots on my b16 but when i spray it it doesnt feel like 75 shots it feels like 30max what could be causing this my bottle is full
hey i dont have a nitros bottle pressure gauge so i cant tell the tempeture of the bottle but what happens if it not at 900psi could that be it need serious input please help
Old Dec 22, 2008 | 05:24 AM
nuclearhappines's Avatar
Default Re: yea nitrous not working good
if the pressure is low you will get less n2o and you'[re still getting the same amount of fuel , you'll lose power on both ends (less n2o, and a rich a/f ratio)
but it could be other things ... how much timing did you pull out, how well was it tuned before hand ...etc
Old Dec 22, 2008 | 05:55 AM
vantta's Avatar
I have a doubt
I own a 10lbs NOS bottle, the pressure gauge reads up to 1500PSI, and the relieve-pressure valve opens at 3000PSI. What is the maxium safe pressure? Because if you heat the botle, the pressure will raise
Thnks!
Old Dec 22, 2008 | 07:26 AM
SilverEk3dr's Avatar
Its almost a MUST to have a press. gauge for nitrous. Most systems are designed to be used between 1050 and 900 psi! If you're under those numbers then you need a bottle heater. If you go over then you have a chance of leaning out and kaboom.
Time to buy my direct port kit :p
Old Dec 22, 2008 | 08:15 AM
bossm's Avatar
yea im going to get a bottle pressure gauge but i hope thats the problem cuz i dont wnt to have more problems with it but i will have to wait and see about the bottle heater cuz i dont know my pressure yet
Old Dec 22, 2008 | 08:16 AM
bossm's Avatar
ow and i retarted the timing by 2 deg
d15.hatch
Apr 4, 2006 03:29 PM
tweekerz
Aug 22, 2005 02:02 PM
ZexyAccord
Mar 8, 2005 01:27 PM
InLimbo87
Nov 30, 2003 09:35 PM
vtecman253
Sep 3, 2003 09:59 PM
